24# injectors question
  • Thread starter Thread starter BlackSunshinelx
  • Start date Start date Jun 12, 2004
BlackSunshinelx
86
long island,ny
Jun 12, 2004
  • Jun 12, 2004
I was wondering if i could lower my pressure down with my 24# injectors so the car doesnt run as rich.I have the Stock ECM and i dont have a chip yet.I would like to throw in my Cobra ECM and i am just waiting on the cobra mass air meter.But i want to make the car run smoother and its running a bit rich with the injectors in it now.The pressure is at 38 now.Should i lower it?Or just drive it as is.
drgn5.0
603
  • Jun 12, 2004
yeah you can definitely lower it and it will work ok.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jun 12, 2004
  • Jun 12, 2004
It's a step down to swap out your current Mass Air computer for a Cobra ECM. There's nothing performance about them. They were programmed to make a good engine combo meet emmissions. Only benefit of them is they are programmed for 24# injectors.
If i were you, i'd stick with the computer you have no and get a MAF meter programmed for 24's
BlackSunshinelx
86
long island,ny
Jun 12, 2004
  • Jun 12, 2004
WEll i have the meter for the 24#ers and i got the cobra ecm because its pretty much a cobra spec motor.How low should i go for the pressure?
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jun 12, 2004
  • Jun 12, 2004
Well you can't use the meter for 24's and the Cobra ECM together because the cobra uses a meter calibrated for 19's and changes it to 24's internally. If you wanted to use the Cobra ECM, you would need a meter calibrated for 19's.
You would be better off staying with the ECM you have now. The A9L and A9P are the most aggressive stock mustang computers. The cobra would be a step down.
39psi is stock pressure. How can you tell you are running rich? The computer can compensate at part throttle conditions by adjusting the injector pulse width. The only time it has no control is WOT when the injectors fire at whatever fuel pressure is set at. If you lower the pressure you will run leaner at WOT.
Part throttle though will be adjusted for. If you run rich at part throttle, lowering the fuel pressure will do nothing as the computer will signal for the injectors to just stay open longer. After a while you will be back to square 1. If you lower the pressure enough, you will be at 100% duty cycle which is not good.
WHat is causing the rich condition? o2's brand new? ANy check engine codes?
I would go for a custom burned chip anytime over a Cobra ECM. With the chip, you should return to a stock meter set for 19's and burn a chip adjucting for the 24's. Thats the correct way to do it. Sometimes, calibrated meters can cause small problems. With all the advances and ease of chip tuning, guys should really move away from calibrated MAF"s and program the injector size into chips.
BlackSunshinelx
86
long island,ny
Jun 13, 2004
  • Jun 13, 2004
Yea, the o2's are new, and so far no codes.It just smells rich, and the idle seems a bit rough.Got a nasty low rpm vibration too.Not sure what that is yet.
BlackSunshinelx
86
long island,ny
Jun 13, 2004
  • Jun 13, 2004
I would probably be better off with stock injectors and a pro-m huh?
K
kwright1900
  • Dec 28, 2004
Did you guys ever resolve this issue? I am having similar problems except I have a 1993 Cobra.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Fuel Fuel Pressure Issue
  • justadude07
  • May 12, 2025
Fox 5.0 Mustang Tech May 12, 2025
justadude07
J
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
