289 heads
I have the 54 cc 289 heads on my car now, I looked into getting them worked but for the price (about $700-900 depending on level you want) i spent another $300 and got a set of new 165 AFR's, they will flow better and weight 40 lbs less than the worked heads could come close to...my .02....
Good move. But you should have those shaved to 54cc (max recommended on those heads, as I understand) to keep decent compression. You may also look at getting a used 302 rotating assembly (cheap, cheap!) for a nice bump in both compression and performance.
