Joes95GT said:I hope the axles don't bend...
Joe
Such as swapping the 8.8 for a 9 inch?95YellowGTbeasT said:different diff. and 31 spline axels![]()
Nick
There isn't much that you can do to reinforce stock parts.ShiftTheDrift said:Joe, that's kinda what I'm afraid of and I started this thread...
Perhaps I'll get to the point faster next time.![]()
What else should I re-enforce to make sure something like that doesn't happen?
What size are the rims and slicks?ShiftTheDrift said:and the other thing is...![]()
How much top speed in the 1/4 am I going to sacrifice before I start running outta gear?
How much can this affect my times?
95YellowGTbeasT said:wouldnt the drive shaft break before the axle????
Nick
The driveshaft wouldn't break. A U-joint may snap, but I don't see a U-joint snapping before an axle bending.95YellowGTbeasT said:wouldnt the drive shaft break before the axle????
Nick
Assuming you use a 28x10.5x15 slick, you will be running between 115-117 MPH @ 6000 RPM in 4th gear. Stay away from a 26" slick because you will need 5th gear on the drag strip. With your regular street tires, you may be able to get the car up to 110 if you bury 4th gear.ShiftTheDrift said:Well, that's just the thing this week... I'm trying to rap up the research for those exact questions. I wanna be able to order them Monday, however, there again, I'm afraid my experience is going to steer me in the wrong direction.
, it's used for nothing but track.
