I have heard so many positive things regarding putting 3:73 gears in my automatic Mustang. I was going to by some and have my garage install them. This is the description of the ones I was looking at. Are these what I should buy? Is $159. a good price? Here's the description:
3.73 Genuine Ford Racing Mustang 8.8" Rear End Gears Ford Racing # M-4209-F373N
Replaces M-4209-F373. New manufacturing technology utilizing a Face Hob Process which features a single pass pinion tooth machining operation compared to a conventional three pass process for machining. CNC cut and lapped gear teeth. Higher strength and better quality gears are produced with the Face Hob Process. Note: These new gears look a little different, the gear teeth are cut on a different angle and the ring gear has a bevel on the back of the gear.
This kit comes complete with the Following:
- 3.73 Ring & Pinion Gears M-4209-F373N
- Ford Pinion Shim Kit
- Ford Pinion Nut
- Ford Crush Sleeve
These will fit any Ford Vehicle with a 8.8" Rear end.
These Are brand New and in the Box!!!
Thanks
- Ford Pinion Nut
- Ford Crush Sleeve
Thanks
plus when you take someone for a ride that has 3.73s or lower in their car,they will get out of your car going :worship:
