3.73's and pullies overkill???
  • Thread starter Thread starter D's 91 stang gt
  • Start date Start date Nov 28, 2005
D
D's 91 stang gt
43
  • Nov 28, 2005
I just installed and set of 3.73's long tubes and x pipe I love it so far like a whole new car I also have a set of mac underdrive pullies but I'm hesitant to install the because the car is running at higher rpms now so my question is would installing the pullies be even more wear and tear on the engine or should I go ahead and install them?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 28, 2005
  • Nov 28, 2005
U/D pulleys will slow down the accessories, that will help with wear and tear technically.
Gears, longtubes and pulleys are a nice start for a stock car.
I
IntenseBlue
946
  • Nov 28, 2005
Put them on.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 28, 2005
  • Nov 28, 2005
If you're running the stock 65A alternator, and have to deal with a/c/hot summers/traffic -- the u/d's may cause some charging and/or cooling issues. No way to know except by trying them. And likely they won't show up til next spring when it starts to warm up again. If the car is otherwise stock, I'd sell the pullies, and put the money towards having tmoss port your stock lower intake. That will work well with your other changes. Weld-in subframe connectors will make a big difference as well.
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Nov 28, 2005
  • Nov 28, 2005
UD pulleys spin all the pulleys less revolutions per minute ... it creates less wear overall.
The downside/trade off is the waterpump will flow less gph at idle, as well as the alternator producing less amperage. The typical solution if you run into charging issues is to buy a larger alternator (130amp) that puts out more at idle.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 28, 2005
  • Nov 28, 2005
i like the UD pulleys but i ad to upgrade my alt
stang2841
708
palm harbor florida
Nov 28, 2005
  • Nov 28, 2005
or dont install your alternator pulley...
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Nov 28, 2005
  • Nov 28, 2005
That will save a few amps and might be enough if charging becomes an issue ... but the alternator still rotates a little less than stock, because the crank pulley has a smaller circumference.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 28, 2005
  • Nov 28, 2005
Keep in mind that many u/d kits (if not most street u/d kits) have a pulley that's designed to OVERDRIVE the alternator - in order to speed it back up some to avoid charging issues. If you leave that one off - you may actually be making the charging issue worse. The key is compare the alt. pulley diameter to the one in the kit for the alt. If the kit pulley is SMALLER than the stock alt. pulley, then you want to put it on to speed the alt. up.
A smaller DRIVE pulley slows everything down. A smaller DRIVEN pulley (alt. is a DRIVEN accessory) speeds that accessory up.
A LOT of people have added u/d's thinking they were bolting on 5-8HP for about $80. In the end after adding a larger radiator and electric fans to solve cooling issues, and upgrading the alternator to solve charging issues (exacerbated by the electric fans) their cash outlay was more like $500-700 and their HP gain was more like 3hp, and most of that only above 3500 rpm which is achieved pretty rarely in normal street driving.
I would suggest trying the u/d's and see what you get. If they cause problems -- you'd probably be better off removing them and going back to the stock set up.
Intake, intake, intake.....the stock lower is the most restrictive piece on the motor. A port job by tmoss won't cost much more than u/d's -- but will deliver MUCH more without any downside.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Nov 28, 2005
#10
  • Nov 28, 2005
  • #10
I installed a set of March "Power and Amp Series" pullies about two years ago. I have had no problems charging or cooling whatsoever, even with the AC on. Fit and finish is excellent. I also have 3.73's and full exhaust. Great set-up.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,119
224
Massachusetts
Nov 28, 2005
#11
  • Nov 28, 2005
  • #11
Run the Underdrives with an OVERDRIVE alt pulley.
That's what i have and i have ZERO charging probs with my 130AMP alt and SN95 electric fan.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 28, 2005
#12
  • Nov 28, 2005
  • #12
D's 91 stang - Here's the most important part of the thread: What happens on someone else's Stang has no bearing at all on what's gonna happen with yours. There are WAY too many variables to make how they worked on one car in certain traffic conditions with certain mods in certain weather patterns predictive of how they're going to work on another.
The ONLY way to know what's gonna happen with yours is to try them.
$uperstang
476
Detroit, MI
Nov 29, 2005
#13
  • Nov 29, 2005
  • #13
Mike is right but for the info no problems with my MARCH pullies and stock alternator
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
For Sale 2003 mustang GT
  • jimted79
  • Mar 22, 2025
SN95 Mustangs For Sale (1994-04) Mar 22, 2025
jimted79
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
