3 part engine question
  • Thread starter Thread starter chucks1967
  • Start date Start date Mar 27, 2008
chucks1967
54
  • Mar 27, 2008
Ok so I am doing a simple intake swap... and everything is/was ok untill I took off the old intake manifold (2bbl intake with 289 stamp on it). I get it off and in the lifter vally there is a 302 stamp? What? so now im confused. is the block not orrigonal. the stamp on the finder says the engine code is "c" which I thought was a 289 2v 200 HP. I knew when I bout the car that the previous owner had put in a cam and headders, but said the block was orrigonal. have I been lied to? and the second question is should I care...... Third part of this question is I was under the impression that the push rods should not be able to spin with thumb and forefinger when pre-loaded... is that true and if so should I adjust my lifters.... the engine ran great before the intake swap, but should I adjust now that i have the intake off.
Thanks in advance.
LMan
1,246
Mom's basement
Mar 27, 2008
  • Mar 27, 2008
1. 1967 was a crossover year from 289 to 302. No surprise that you have a 302-stamped block.
2. It doesn't matter.
3. You cannot adjust hydraulic lifters. Don't worry about it.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Mar 27, 2008
  • Mar 27, 2008
+1, If you have stock rockers then there's no adjustment...they are simply torqued down.
chucks1967
54
  • Mar 27, 2008
ok.... so if Im understanding you correctly.... the 67 engine could still be a 289 just with 302 stamped on the block, or is it truly a 302 advertised as a 289..... if it is a 289 is it just a de-stroked 302? if so that’s cool, and I said lifters I had a brain fart and ment to say rocker arms.... they are not adjustable?
When I was taking out the old intake, the bolts were not tight at all, they could be removed with very little effort. What are the torque of the intake bolts and what pattern should they be torque?
rbohm
6,698
550
204
tucson,az
Mar 27, 2008
  • Mar 27, 2008
i also have a 289 block from 1967 that has the 302 cast in the valley. no big deal. measure the stroke to see which crank you have. by the way 1968 was the crossover year for the 289 to 302, NOT 1967.
remember that the 302 is a factory stroked 289. ford wanted more low end torque from the little engine because the cars were getting heavier, so the added .13" of stroke.
to determine of you have adjustable rocker arms or not, pull one rocker arm and look at the stud. if it has a shoulder just below the threads, then you have non-adjustable rockers. if on the other hand the studs are straight then you have adjustable rockers.
chucks1967
54
  • Mar 27, 2008
Would you think that there was any kind of vac leak arround the intake because of the intake bolts being loose....
D
D.Hearne
11,730
south louisiana
Mar 27, 2008
  • Mar 27, 2008
I think the real reason for Ford's stroking the 289 to 302 was for Trans Am racing, to take advantage of the 5 liter displacement limit. Otherwise I agree with all everyone's posted. No surprise that the intake bolts would be loose. They're only torqued to 20-25 ft/lbs to start with and over time, the gaskets settle and they'll loosen up. But once the gaskets have bonded and the seal made, there's little chance of vaccum leaks.
rbohm
6,698
550
204
tucson,az
Mar 27, 2008
  • Mar 27, 2008
DH, i agree with you to a point. remember that the 5 liter rule was around from the beginning, and ford could have taken advantage of it at anytime. however since the 289 was doing so well in both B production racing, and in early trans am racing, they decided to leave well enough alone, until chevrolet came out with their 302 in 1967, thus ford had to respond in kind.
D
D.Hearne
11,730
south louisiana
Mar 27, 2008
  • Mar 27, 2008
Yea, you're probably right there.
H
htwheelz67
444
mission viejo ca.
Mar 27, 2008
#10
  • Mar 27, 2008
  • #10
you were lied to.......its a 302 more than likely unless someone put 289 internals in a 302 block.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Mar 28, 2008
#11
  • Mar 28, 2008
  • #11
For the torque value and sequence on the intake, double check the manual, but I believe for stock it's about 25 ft lbs and it's an inside out torque pattern like the heads...but double check that. If you have an aluminum intake I'd torque to 20 ft lbs.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
T
Engine 1970 302 boss block
  • TOM B
  • Jan 4, 2025
Classic Mustang Specific Tech Jan 14, 2025
lqbbe
L
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
