302 heads
  • Thread starter Thread starter 67Flashback
  • Start date Start date Jan 4, 2010
67Flashback
  • Jan 4, 2010
I have a 71 coupe that needs the valve seals replaced. The motor is not the original and it has an Edelbrock performer cam and intake. It also has headers with flowmasters. What I was wondering was, since I need the heads done, is there anything I can do to get more performance from them without spending a lot of money or is it even worth it? any help would be appreciated.
woodsnake
1,352
15
69
Hicksville, NY
Jan 4, 2010
  • Jan 4, 2010
Valve seals or guides?
You can replace the valve seals with out removing the heads.
You may be able to get a set of fresh performance heads, cast or aluminum for less than a stock rebuild.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jan 4, 2010
  • Jan 4, 2010
Yes! Port-match the exhaust to the manifolds/headers, and remove any Thermactor bumps from inside the ports. It'll feel like you got a better cam. You can do this yourself in a couple hours, I did mine.
The exhaust ports of the 289/302 had an adequate design, but in practice there was usually a lot of casting flash around the opening, and the Thermactor bumps added later were so bad you'd think spies from Chevy put them there.
D
D.Hearne
11,730
south louisiana
Jan 4, 2010
  • Jan 4, 2010
He can also replace the valve seals too himself. But if they need guides too................ and seats, & valves, springs.....................might as well buy new or secondhand aftermarket heads. It's a slippery slope with 40 year old heads.
C
C0V3R
524
Australia
Jan 4, 2010
  • Jan 4, 2010
If you need to recondition the heads, I would get a quote/price before doing anything. It is likely to cost you a good portion of what a set of brand new aftermarket heads would cost.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
