302 heads
67Flashback
I have a 71 coupe that needs the valve seals replaced. The motor is not the original and it has an Edelbrock performer cam and intake. It also has headers with flowmasters. What I was wondering was, since I need the heads done, is there anything I can do to get more performance from them without spending a lot of money or is it even worth it? any help would be appreciated.
Yes! Port-match the exhaust to the manifolds/headers, and remove any Thermactor bumps from inside the ports. It'll feel like you got a better cam. You can do this yourself in a couple hours, I did mine.
The exhaust ports of the 289/302 had an adequate design, but in practice there was usually a lot of casting flash around the opening, and the Thermactor bumps added later were so bad you'd think spies from Chevy put them there.
He can also replace the valve seals too himself. But if they need guides too................ and seats, & valves, springs.....................might as well buy new or secondhand aftermarket heads. It's a slippery slope with 40 year old heads.
If you need to recondition the heads, I would get a quote/price before doing anything. It is likely to cost you a good portion of what a set of brand new aftermarket heads would cost.
