This is an 82 302 with a T5 tranny in a 66 convertible.
The idle is quite rough to the point where I cant get it below 650 rpm without taking a chance on the engine stalling. Even with the idle speed adjusted at 700, when I start the engine warm after it has been sitting for a few minutes, it's is still VERY rough. After a couple of minutes of giving it some gas (keeping it around 1000 rpm or so) it will idle ok at 700.
This is what I've done:
New edelbrock 1406 carb and I've adjusted both the idle setting screws.
New distributer and timing has been set to about 10 degrees. Vacuum advance on the distributer is connected to the driver's side port (constant vacuum)
Have gone around and checked for leaks in all vacuum fittings and found none.
Using a vacuum gage, I found that the vacuum is about 13" at idle (set at 700 rpm for now). it does fluctuate between 14 and 12 (in time with the rough idle on the engine). When I give it throttle, the vacuum goes up to about 21" and stays steady (held it at 1500, 2000, and 3000 rpm and it stays about 21"). When I let off the throttle, the vacuum jumps up to 25' and then back down to 13" at idle again.
I did verify that the vacuum gage is accurate beforehand (I have access to a low pressure calibrator) and it is.
Any ideas?
Any ideas?
