302 options
  • Thread starter Thread starter cjperry81
  • Start date Start date Mar 11, 2008
C
cjperry81
53
Lebanon, OHio
Mar 11, 2008
  • Mar 11, 2008
I am planning on doing a I6 to V8 swap in my 66. I have been looking for 302 's lately and have come across several on the net. I know that alot of people on here talk about using an 88-93 engine but I have also come across a couple 1970 302's and I am wondering what the real differemce would be and is one a better choice than another. I plan on rebuilding the engine no matter what but just wondered if I should pick one over another.
SadbutTrue
2,391
Thousand Oaks, California
Mar 11, 2008
  • Mar 11, 2008
The later ones have roller cams, which have a host of small advantages over older non-roller cams (wider powerband, slightly more power/mileage, easier to tame on the street, etc). They should also come with EFI equipment, which again could be desirable (again, minor improvements in performance and drivability). Plus the later model E7 heads aren't bad. And they come with forged pistons (some of them, anyway).
Definitely want a late model 5.0 if you can get one.
67rcks
373
Mar 12, 2008
  • Mar 12, 2008
I think around 1985 5.0 mustangs came with roller lifters and carb, these are fine if you don't want to do efi conversion.
jspagna1
53
Connecticut
Mar 12, 2008
  • Mar 12, 2008
Just a suggestion, would you be better off buying a crate motor instead. I would think after all is said & done with machining the block and having the motor rebuilt? Unless you are going to rebulid it yourself?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Mar 12, 2008
  • Mar 12, 2008
Depends what area you are from. If you find a motor at a junkyard you can get them really cheap sometimes. You can come out WAY a head. The main problem is finding a good/reliable/affordable machinest.
Sicarius428
2,085
Mar 12, 2008
  • Mar 12, 2008
In my area an HO longblock from 88-93 will run you about 450 bucks and are very easy to find in good condition. They can typcally handle 450hp before they split. The early 302 blocks are a tad stronger but as said before, roller cams, small upgrades and a plethera of aftermarket parts driven by the fox plaform really make the last generation of 302s probably ideal for a swap. E7 heads aren't bad but the stock HO intake is the chokepoint. If you stay carb get a stealth and you should be set.
Kevin
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
