M MotorcityCobra New Member Jul 30, 2007 1 0 0 Dec 2, 2007 #1 Dec 2, 2007 #1 I thought these were not interchangeable, but I'm just learning about Fords. A guy from Roush insists that a 351w will fit my 302. Is this correct?
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Dec 2, 2007 #2 Dec 2, 2007 #2 a 351w intake will not fit a 302, but with the right adapters a 302 intake can be put on a 351w.
CraigMBA New Member Mar 24, 2007 783 1 0 Orange, CA Dec 2, 2007 #3 Dec 2, 2007 #3 The guy at Roush is on crack. rbohm said: with the right adapters a 302 intake can be put on a 351w. Click to expand... Yeah, but why would you want to?
Fast63 New Member Sep 20, 2007 717 0 0 Dec 2, 2007 #4 Dec 2, 2007 #4 351W and 302 HEADS are interchangeable.
dennis112 15 Year Member May 15, 2005 1,561 36 79 Amish Wonderland of Central PA. Dec 3, 2007 #5 Dec 3, 2007 #5 Fast63 said: 351W and 302 HEADS are interchangeable. Click to expand... Yes, but the 351W block is about an inch taller and wider than the 302.
B bnickel Founding Member Aug 21, 2002 5,640 3 77 lubbock, texas Dec 3, 2007 #6 Dec 3, 2007 #6 dennis112 said: Yes, but the 351W block is about an inch taller and wider than the 302. Click to expand... heads will interchange but intakes won't.
dennis112 15 Year Member May 15, 2005 1,561 36 79 Amish Wonderland of Central PA. Dec 4, 2007 #7 Dec 4, 2007 #7 bnickel said: heads will interchange but intakes won't. Click to expand... That is what I was really trying to say, but I guess it came out wrong. Thanks for the backup.
SoCalCruising Founding Member Jul 25, 2000 2,437 0 47 SoCal Dec 4, 2007 #8 Dec 4, 2007 #8 This is all assuming carb's intake. However, an upper from an EFI intake will fit either 302 or 351, but the lower won't interchange.
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Dec 4, 2007 #9 Dec 4, 2007 #9 CraigMBA said: Yeah, but why would you want to? Click to expand... if you had an intake that was unique to the 302, but wanted to put it on a 351w or even a c, then the only way is intake adapters.
