Hello, I have a few questions about building my first motor. I have seen stroker kits online and I like the ones from Speed-O-Motive. Has anyone bought from them before? How did you like it? Can you recommend any machine shops in the Sacramento, CA area?
I have a 66 with a 4 speed and right now I have a running 1970 302 from a Torino under the hood. I also have a 94 5.0 motor from a wrecked automatic mustang sitting in my garage. It has never been rebuilt. The problem with the 5.0 motor is that I have a 4 speed and the block does not have a place to screw in the shaft that the z pedal pivots on. Is there a kit or something that can be done so I can use that block or am I better off using the older block if it checks out? What about my flywheel and balancer? I have an old motor and I am assuming that I have the 28 oz. balancer, will I have to use a new 50oz flywheel and balancer or will I be able to use the stuff I already have in the car right now? What will I be able to bolt up to the new block, like the water pump, fuel pump, dipstick, timing chain cover, ECT…?
Thank you
Thank you
