306 in.... Cooling problems...
95CobraMike
1,046
Lima OH
Well i finished my 306 build up and its in and running!
But im having cooling problems... again
here is what i do...start the car without the radiator cap on, wait till it warms up and fill it unil it stops bubbling... cap it off and go for a drive.... everything if fine no problems what so ever. turn the car off, 5 min later turn it back on and the thermostat opens and the temp keeps climbing till the L in normal almost to the HOT mark.... open the Radiator and fill it till it stops bubbling cap it off and im good to go again.... it is so intermintant too, sometimes it does it sometimes it doesnt
there is no white smoke out the exhaust and no crap in the oil.... not sure where its going? maybe out the over flow tank?
Fluidyne radiator, and a newer 180* t-stat....
:shrug:
If you still have ait in collant system you will have to drill hole on thermostat about 3mm (don't remember now how much on USA messurment because i'm frickin European :D ) and you will need good drill bit because thermostat is made from stront a$$ material
Drill hole like in pics
Put the hole on the top.
I have had pretty good luck without a hole in the t-stat by jsut filling the radiator (car off) and continuously squeezing the upper radiator hose unitl no more coolant will fit. Then I start the car with the rad cap off and top it off, put the radiator cap back on and fill the overflow tank to the max line (about 1/2 way up). then jsut check it in a couple of days.
Burping-Start the car with rad cap off and heat HIGH on the Normal setting. Wait for the stat to open. Fill rad back up. You can do this a couple times on the cold cycle. DO NOT do it when the car is hot already (safety issue).
What??? Meaning heat high, fan low? or heat high, fan high? or heat high floor only? or heat between cool and hot with the fan on high? not sure what you mean
i think you mean all the way as hot as it will go and all on the floor....
Turn the heat on at it's hottest setting. The fan on it's highest setting. Instead of MAX put it on NORMAL. Start car without cap wait for the stat to open, refill and wait until all the bubbles disappear. Put cap back on.
i dont have a MAX or normal Heat setting.... i have 3 knobs....
fan you say...high
Heat/cool you say all the way to the red...
the other knob says off, floor, vent, mix, defrost, normal AC and MAX AC...
you mean turn this one to the normal AC setting?
i tried it, but i didnt have the chance to drive it. so ill try it tomorrow.... but i put in the original overflow tank instead of 2-liter bottle.... new Rad. Cap. and i did VIB's method.... so we'll see
