306 missing really bad!!!!
  • Thread starter Thread starter FoxRacer045
  • Start date Start date May 2, 2011
FoxRacer045
52
Whitewright
May 2, 2011
  • May 2, 2011
Okay guys, I have a 306, bcam, eddy heads, eddy upper & lower, 24 lb injectors c&l mass air, c&l CAI, BBk long lubes. When I first start it up it misses at idle, when I start driving it misses so bad it will not go till i let off the gas then it will idle, but give it gas just dose not want to move!!! After a little bit it will drive but miss the whole time. I have done plugs, wires, cap, rotor, computer, new dizzy, check vac leaks no leaks. Im at a lose any ideas would be great.
Thanks
Shane
HISSIN50
34
129
May 2, 2011
  • May 2, 2011
Have you pulled codes and done a cylinder balance test?
FoxRacer045
52
Whitewright
May 2, 2011
  • May 2, 2011
Nope not yet, about to do a compression test! Ive never pulled codes on a fox?
HISSIN50
34
129
May 2, 2011
  • May 2, 2011
I would pull codes and do the CBT before doing a compression test.
FoxRacer045
52
Whitewright
May 2, 2011
  • May 2, 2011
Well i think its time for a rebuild lol! Guy before me sprayed this car. Didnt tell me but when i went to change plugs, there where nitrous plugs gaped at 35. Fuel pressure holds perfect but my miss is most likely low compression.
#1-60
#2-65
#3-60
#4-60
#5-55
#6-55
#7-50
#8-50
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 2, 2011
  • May 2, 2011
Cylinder balance test:
The computer has a cylinder balance test that helps locate cylinder with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
See the link to my site for details on how to build your own blow down type compression tester.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 2, 2011
  • May 2, 2011
Check firing order?
FoxRacer045
52
Whitewright
May 2, 2011
  • May 2, 2011
85_SS_302_Coupe said:
Check firing order?
Yes a couple of times!! But with the compression test results im guessing rings are toast. I added some oil in the spark plug hole and it jumped up.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 2, 2011
  • May 2, 2011
Even still, would bad rings cause a bad miss? Seems it would just smoke and burn oil, not miss.
FoxRacer045
52
Whitewright
May 2, 2011
#10
  • May 2, 2011
  • #10
I ask around said there would be poor low end, and could miss at low end. Not sure tho!
HISSIN50
34
129
May 2, 2011
#11
  • May 2, 2011
  • #11
Was the engine hot and the TB propped open (with the ignition disabled)?
FoxRacer045
52
Whitewright
May 2, 2011
#12
  • May 2, 2011
  • #12
yep yep!! Got the same readings cold and hot
ID89GT
1,659
18
49
Spokane Valley, WA
May 2, 2011
#13
  • May 2, 2011
  • #13
Wow those are some pretty low numbers
HISSIN50
34
129
May 2, 2011
#14
  • May 2, 2011
  • #14
You should not get the same readings on a cold motor as with a warm motor.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
May 3, 2011
#15
  • May 3, 2011
  • #15
Those numbers are pretty consistent though. Makes me wonder if there was an issue with the test vs the actual compression being low
FoxRacer045
52
Whitewright
May 3, 2011
#16
  • May 3, 2011
  • #16
I did it the only way i know how. Did the wet test to! And the numbers jumped up!
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
