- May 3, 2002
- 161
- 0
- 17
Im in the process of building my new engine. I want to buy aftermarket rods and pistons, so I figured I might as well go with a stroker. But my limiting factor is my stock block. I plan on running an s-trim with 12-15 psi making about 550-600 HP. Would a 306 be a better choice if I want my block to live or will the 331 hold up. And if I use H-beam rods compared to I-beams how much heavier are they and will they affect my block standing up to this power. I've already got AFR 185's and a Trick Flow R intake which should work well with this combo so would this be a good choice?
Thanks
Thanks
