89CopCoupe said:I'm with you on that one ... ohhh how I know your pain![]()
However many things look great on paper, and Voila! ... work out in the real world as well ... like the new MGW shifter I just ordered![]()
Your right sometimes they do. I guess it all depends on the quality of the engineer and where their priorities and goals are set. The engineers that designed the newer GM trucks and SUVs I would like to shake thier hand, the one's who designed the Chrysler Concord, LHS, Intrepid I would like to kick them square in the nuts. Back to the stroker...
We can argue about rod ratio's and how they effect longevity but when your racing someone that is the last thing on your mind. We all know that the weak point of the 302W block is right down the middle, not the cylinder walls, so with that in mind STROKE IT LIKE A ASIAN MASSAGE PARLOR!!!
It's the 302 based stroker some of you seem to fear... So why if it is such a bad motor why is it original equipment in some cars??? Fact is the days of the oil burning piston slapping 347's are over LONG OVER so get over it and stroke away. While your at it why not just step up and do a 351w based stroker
not that I'm biased or anything.. BE WARNED I will slap the crap out of anyone dumb enough to tell me a 351w conversion is expensive or hard.
You betcha ... 'cause most every other profession is SOOOOOOO exciting
