31 spline set up...
iwannarace67
210
Chicago, IL
Been tryin to peice together a semi budget 31 spline conversion. I was basically going to go with FRPP everything. So far my shopping list is:
FRPP 31 spline diff
FRPP 31 spline axles
FRPP 4.10 rear gear w/ master bearing kit (motive)
Royal Purple gear lube
Am I missing anything else? Do the FRPP axles come with ABS rings or no? Also I see most people running with the Eaton diff/ moser axle set up, is the FRPP stuff not that great or what? All input appreciated...
Not sure how much the FRPP axles are, but I'd bet Moser axles are the same or less and better quality.
You could save yourself some monery and rebuild a used traction-lok out of a 4.0V6 8.8 Ranger 4x4 or F-150 or Bronco, or any truck 8.8 rear end. They are all 31 spline and they made about a zillion of them, so you should be able to get one for next to nothing. T-Lok rebuild kit is like $60 bucks.
FRPP 31 spline diff
Might as well add "Welding the axle tubes' to your list. Would be a shame to have a built rear and having an axle tube snap on you.
iwannarace67 said:
Call me new I guess but can I get a quick explanation of welding axle tubes?
Axle tubes are pressed into the center housing on the 8.8. Welding them to the housing prevents any unwanted twisting or moving of the tubes in the housing.
