just a thought but would it be feasible to run higher compression and have fun and when ready to run forced induction to just swap in some cometic head gaskets since you can choose thickness? i don't know much about those but i thought i read something like that??? just an honest question to learn more.
I have been thinking about yanking the shortblock in selling it if anyone is interested I HIGHLY DOUBT that that combo above dynoed at 500rwhp
The 3.25" stroke (331) and 3.4" stroke (347) both make similar power numbers.
The 3.4" stroke DOES have a steeper rod ratio.
A stock 5.0L displacement is 302 cubic inches. It consists of a 3.00” stroke and 4.00” bore. The stock rod is 5.090”.
A 306 is created by reusing the stock 3.0” stroke but boring/honing the cylinder walls .030” to create a 4.030” bore. It necessitates an oversized piston, larger than the stock 4.00” stock bore/piston. A 306 is a form of a budget build and is not intended to make extra power, but more to create fresh cylinder walls for longer engine life and revive lost compression through high mileage engines.
Both the 302 and 306 reuse stock 3.00” crank and stock 5.090” rods. The 306 needs new oversized pistons.
A 331 cubic inch engine (stroked 302), consists of a new crank of 3.25” of throw, and the 4.030” overbore that creates fresh cylinder walls. To get the 331, you need a crank, of 3.25”, new rods of 5.315” or 5.4” length, and a .030” overbore from stock bore.
A 347 consists of a 3.4” stroke, 5.315” or 5.4” rod, and oversized pistons of 4.030”.
Most 347’s need extra block clearance to clear the rod bolts as a crank rotation is being made. The throw of the crank is too large to have safe tolerances to rotate.
Piston speed in feet per minute:
A 302 with the 3.00” stroke moves 3,000 feet per minute.
A 331 with the 3.25” stroke moves 3,250 feet per minute.
A 347 with the 3.40” stroke moves 3,400 feet per minute.
Excellent info and unbias below:
http://www.fordmuscle.com/archives/2003/09/stroker/
If you want to read about how rod ratios effect performance...read this:
http://www.strokerengine.com/RodStroke.html
If you are going to build a true street car (daily driver), get the 5.315" rod. The only real advantage the 5.4" rod has is it's longer dwelling time (very very slightly different) at BDC/TDC which gives those drag racer/track kings that very slight edge over the next guy.
Daily Driver = 5.315" rod
Track Car = 5.4" rod
http://www.mustangandfords.com/techarticles/5197_331ci_stroker_engine/photo_07.html
Left is a piston with the wrist pin intersecting the oil ringland. 5.4"
Right is a piston where the wrist pin does not intersect the oil ringland. 5.315"
If long engine life and reliability are your goal (daily driver), keep the piston pin out of the ring area. Having the piston pin close to the hot piston crown is just asking for premature engine blow-by or even failure. The oil struggles to stay on the wrist pin/boss because heat chases it away.
It is a very easy concept.
So in short, to get the cubes and best reliability from those cubes possible, you can go 331 or 347 (5.315" rod). Get the cubes and mileage you are looking for = 5.315" rod.
Remember it is your money that you are spending.
Good Luck!
i had to notch my cylinder skirts to get the rod bolts to clear on my 331
Good articles 5spd. It's nice to be able show people what you're talking about. I hate hearing the "technology today allows 347s to run without a problem." If I feel like being a dick, I'll just ask them to clarify the amazing new technology that has been invented?
Another big thing to consider in the differing rod lengths is the compression height of the piston, which is usually not a big deal on naturally aspirated engines, but on monster boosted engines, the added compression height necessarily strengthens the crown of the piston, which like you mentioned also helps to keep the heat away from the pin. The added length of the rod directly reduces the amount of compression height you can have.
For this reason, CP pistons all but refused to let me go to a 347 with my 5.4" rods. They would've done it, but had sort of an "at your own risk" attitude.
If their attitude is that they want the extra power associated with the dwell time with a longer rod, I understand it. If their attitude is that they already have the 5.4 rods and really need the extra 16 cubic inches for power, that's cool too. I would personally just rather have almost as much power and a lot more peace of mind, especially with a turbo car that will make as much power as the turbo powering the engine can make.
Chris
I HIGHLY DOUBT that that combo above dynoed at 500rwhp![]()
Maybe you missed that.You don't think a turbo 347 can get 500rwhp?Maybe you missed that.
With 35# inj. and no tune I see maybe ~250mi to a tank on my 347.
http://*******.com/index.php?topic=6087.0
http://*******.com/index.php?topic=7010.0
Very good info in these threads for those looking to learn facts..
EDIT: s b f t e c h . c o m (no spaces)
'Wiring harness' WTF???Yes, a 351w stroked to whatever would net me more power in the end, but it would probably be more expensive considering I don't have a 351w lying around. Unless someone wants to donate one, and all those wonderful accessories (i.e oil pan, wiring harness, etc etc) I'm going to have to go with the 302 block. Money just doesn't grow on trees.![]()
Can you please elaborate on WHY the ring lands should be lower for boost?Hey, I forgot to mention the biggest reason CP didn't like the 3.4" stroke. The ringlands on high boost application pistons has to be lower, which runs you into a bind if the pin is already intersecting the oil-ringland.
jason
