331 motor and dip stick acting funny...
Piston
215
Chicago Suburbs
Ok, I'm no genius as to what this could be but I have a 331 stroker and when driving the dip stick comes flying out along with oil. Now mind you it doesn't happen until higher rpm's 5k and higher. What the hell is going on here? I didn't have breather cap at first but I do now and I notice oil on the bottom of the hood flying out the breather cap. Is this bad? I don't know if the dip stick flyies out anymore cause I taped it down. Any help would be appreciated.
i had the same issue,tore the motor down.One ring was stuck in the piston
i wanted a reason to tear the motor down anyway,wasnt happy with the moly rings i found out were junk
This blows... I had this motor for no time and it's not working like it should. Dammit. I'm going to check the PCV and Compression thanks guys. Well I sure hope DSS built this thing right and it's just something stupid.
Thanks for the help...
