  • 1994 - 1995 Specific Tech
331 question
  • Thread starter Thread starter gtcobra302
  • Start date Start date Apr 29, 2008
gtcobra302
118
Centra Florida
Apr 29, 2008
  • Apr 29, 2008
My buddy has a 331 in his 94 gt. he is running 30 lb injectors which sound big to me. I am running a 100 shot of nitrous and am only running 24 lb injectors. he is running rich. His car is NA, what do you think?
donkey_punch
565
northern****ingjersey
Apr 29, 2008
  • Apr 29, 2008
check for codes thats the first thing to do, possible O2 sensors need to be replaced, check fuel pressure
95WhiteVenom
624
Alabama
Apr 29, 2008
  • Apr 29, 2008
Fuel Pressure?
gtcobra302
118
Centra Florida
Apr 29, 2008
  • Apr 29, 2008
Not sure of the fuel pressure, what should it be with the line off?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 29, 2008
  • Apr 29, 2008
His injectors are NOT at all to big for a n/a 331. I run 30's on my n/a 347 and they're 100% MAXED out as shown by the duty cycle on my PMS.
How do you know he's running rich?
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Apr 29, 2008
  • Apr 29, 2008
I may have some 36's for you if you want Anyway, I think 24's "can" work in a 331 depending on "supporting cast" and likewise with 30's
RC
BlackVert
5,589
9
98
Bethesda, MD
Apr 29, 2008
  • Apr 29, 2008
30# injectors are not at all too big for a 331. in fact, they may be too small, depending on the heads, cam, and intake. putting down 375 horses at the tires is not unheard of for a 331. at that level, i bet 36 or 42# injectors would be better
gtcobra302
118
Centra Florida
Apr 29, 2008
  • Apr 29, 2008
hes got a cobra intake, 80mm mass air, short headers, gt40 iron heads, cold air intake, a receint tune up, msd cap, rotor and coil, ford racing wires, 70mm tbody and spacer. his tail pipes are black and he uses an inordinate amount of gas. he says it is a wolverine b cam, the guy he got it from was supposedly using a 200 shot of nitrous then he took it off when my buddy got it. It also seems to miss when it gets hot.
earleys94gt
1,223
Ashley, Ohio
Apr 29, 2008
  • Apr 29, 2008
The 30's should be okay.
Has he checked the timing on his car?
Black95GTS
1,644
Marlborough, MA
Apr 30, 2008
#10
  • Apr 30, 2008
  • #10
I think he needs to tune his car. 30 pound injectors will most likely be OK with that combo, though I would steup up to 36 pound injectors.
One thing you both need to realize is that the size of the injector has NOTHING to do with how lean or rich the car runs, its all in what the computer tells the injector to do.
Adam
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 30, 2008
#11
  • Apr 30, 2008
  • #11
It all depends on the top-end pieces.
An N/A 347 could do fine with stock top-end pieces with a 19 lb. injectors and a 5,500 RPM shiftpoint.
Then, you could have issues with 42 lb injectors shifting at 7,500 RPM with a nice top-end.
The best one I have found to use is from FTI's website:
How to Calculate the Correct Injector Size:
IHP = Ideal Horsepower
NIJ = Number of Injectors Used
IDC = Injector Duty Cycle
BSFC = Brake Specific Fuel Consumption
Example:
300 HP / 8 cylinders = 37.5
37.5 X .50 BSFC = 18.75
18.75 / .80 Duty Cycle = 23.43 lb/hr injector (24 lb/hr is the closest).
This will vary per BSFC you want to run and injector duty cycle preferred.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 30, 2008
#12
  • Apr 30, 2008
  • #12
RC
Thanks for the offer but I am going to go 42's when funds allow
94GTLaserRC
11,178
Apr 30, 2008
#13
  • Apr 30, 2008
  • #13
The funds may allow for my 36's...Im not going to be listing them for that much...Oh...and I may have a BBK 75mm TB too
RC
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
