  • 1994 - 1995 Specific Tech
331 stroker questions
  • Thread starter Thread starter SLVRBOY
  • Start date Start date Jul 20, 2008
SLVRBOY
91
st. augustine , fl.
Jul 20, 2008
  • Jul 20, 2008
i have a 331 stroker (street fighter kit) withh dual valve relief pistons and forged internals in a stock block with a stud girdle. the heads are tfs trick flows. i want to put a supercharger on it, my question is what compression, cam, intake, fuel injectors should i run for 10 to 14 psi. it is a daily driver car but work isnt that far. still have a/c and power steering. im looking to get over 450hp at the tires. closer to 500. i know the block is the weak link and i havent looked yet to see what the next block up is.
i am looking at superchargers on ebay and found a couple for $800 to $1500. and what is the methanol injection??
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 20, 2008
  • Jul 20, 2008
I don't have a lot of blower experience but I can share a thought
or two with you
With those heads and other better flowing parts ... you are gonna be asking
for quite a lot at 14 psi ... especially for a daily driver.
I would seem to me .......
you would have to pulley down a good bit to make 14 psi
I also wonder if that free flowing combo combined with 14 psi is gonna
put all those nice parts at danger or will you be below block splitting
territory with your horse power level.
As for inj size I would say ... at least ... 42 pounders ... maybe larger
As I see it ... you should be at 325 to 350 to the wheels with correct
combo parts selection ... WITHOUT ... the blower.
Since you say the application is daily driver ............
I'd go less on the aftermarket parts and more on psi
or
Go more with aftermarket parts and less with psi
I'd not try to go more with both as you will certainly be in danger
of destroying the parts due to the block letting go
A daily driver has to be reliable or you will be left ... hoofin it
Grady
V
viridionplague
98
  • Jul 20, 2008
the thing i dont like about blowers personaly is that it takes power to make power.
500 at the wheels with 15% powertrain loss is 575 at the crank.
add in what the blower takes to turn and your probably looking at over 650 hp total power or more
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jul 20, 2008
  • Jul 20, 2008
There are lots of guys that make over 500RWHP with a 331 and blower. I wouldnt push over that much with a stock block, but it is doable with not necessarily an aggressive tune. Eades made 550 with his combo and the Meth. kit running RICH on 42's.
I just traded my body kit for a barely used Meth kit. Even if you dont use it to make the amt of power you "could" make, definitely doesnt hurt to have the air temp coming in a lot cooler. I would shoot for 8-10 lbs TOPS with a stock block and good flowing components. When purchasing a used VOrtech, I would have a little money set aside in case you need to have the bearings and stuff done. For about $700, they redo the internals and re-warranty it for another year. I had that done on mine.
Good Luck!
RC
Pokageek
2,767
MA, USA
Jul 20, 2008
  • Jul 20, 2008
I wouldn't run that kind of power in a stock 302 block but thats just me. I want it to be around for a while. The girdle will do a great job of keeping your parts from falling out onto the street when it does blow but it wont make it stronger. Save the weight and ditch the girdle.
ProKiller
3,064
15
78
PA
Jul 21, 2008
  • Jul 21, 2008
compression - i wouldn't go anything over 10:1, but 9:1 would be good
injectors - you'll be good with 42s for a while.
cam - either go to FTI or get a blower oriented cam
intake - anything that will flow good. since you have the trick flow heads, i would get a trick flow intake to keep it matched.
block - i feel safer with the internals that i have but the block is still stock, so that is the weakest link. There have been plenty of people that have run 600hp on a stock block and gotten away with it, then there have been others that blow it at 350hp. i say just get a nice safe conservative tune.
meth inj - a chemical intercooler designed to cool the intake air the way an intercooler would generally work. takes a lot more tuning to get it optimized. i've had mine sitting for almost 2 years now waiting to go on.
SLVRBOY
91
st. augustine , fl.
Jul 21, 2008
  • Jul 21, 2008
yea 450 at the tires is good. one of the intakes i was looking at was the bbk. it looks cool but that dont mean it works. an intake and cam is the next step so i can get it closed up.
ProKiller
3,064
15
78
PA
Jul 21, 2008
  • Jul 21, 2008
i only know one person that had that intake and he traded it for a sheetmetal intake. either search or pm 69clark
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
