OK i jsut put in a new 331 and I seem to have some spark knock at high rpm's. Pretty much anything over 4000 or so. Also it seems to want to idle a little rougher than i want . And if you clutch while driving sometimes it will die. I have an appointment to get it dyno tuned on the 27th of April put I wnat to put some miles on it before then. Here s a list of the mods.
331
AFR 185'S
70MM BBK TB
73MM C&L MASS AIR
PULLIES
BASSANI XPIPE WITH CATS/HEADERS
COBRA INTAKE
30LB INJECTORS
HOWARDS CAM 534/547 @.50 224/232
1.6 ROLLER ROCKERS
10.0/1 COMPRESSION
The builder says it should be about 400 at the flywheel does this sound about right???
331
AFR 185'S
70MM BBK TB
73MM C&L MASS AIR
PULLIES
COBRA INTAKE
30LB INJECTORS
1.6 ROLLER ROCKERS
10.0/1 COMPRESSION
