Ordered a 331 stroker with all forged internals and AFR 185 heads. The builder will order the raw 185 heads and cnc them based on his own recipe. The engine will include the following: 5.0 roller block, 9.8/1 compresssion, RPM airgap intake, Demon 650 vac/sec, custom longtube 1 5/8 headers with x-pipe 2.5" exhaust. The drive train will be AOD (2700-2800 stall), 3.55 trac loc rear with 26" tires. My goals and build for this combination is for all around performance, economy and reliability. It's use will be street and roadtrips. I need to pick an off the shelf or custom cam for my application and I'm dizzy after lengthy forum searches but I think I'm learning quickly. The techs at the major cam houses have given different advice everytime I've spoke to them given the same parameters, but they have all seemed to make sense with their suggestions too which is heplful but hence the confusion also. Also have "power" brakes and want med. strong idle but not too crazy. I realize that I'll sacrifice low end takeoff due to my gear ratio and 245 width "new" tires but I'd like to make it up with strong mid/top pull. I will not do EFI but maybe nitrous boost in long term growth plan, also using 1.6 rockers.
Comp has recommended the XE274HR (224/[email protected], .555/.565 lift, 112s- design for EFI but usable for carb too), the Magnum's 280H and 281HR (220/[email protected], .512/.512 lift, 110sep - more designed for carb application with 110 sep.) and maybe a custom grind version of the XE274 with a 110 separation.
Here's my rookie stab at a custom grind: 220/[email protected], .544/.560 lift, 110s.- good for 2000-6000rpm?
Let me know your ideas and suggestions, thanks!
