342 set up
  • Thread starter Thread starter gasngo
  • Start date Start date Sep 14, 2004
G
gasngo
  • Sep 14, 2004
I am building a 342. 302 block std bore, 5140 forged crank w/3.40 stroke, 5.315 rods, probe 1.175 pistons w/14.2cc dish, 302 Edelbrock Victor JR intake. Haven't determined cam yet.
Heads I have are stock 302 58.2cc heads 1.78/1.45 valves gasket matched/light porting ( smothened out and smog bumps removed ). Still have press in rocker studs but will upgrade to screw in's. CR figures out to 9.73:1 with this set up.
Question is will the stock 302 heads with the light porting still allow the 347 to perform well? I know the gt40P's would be a better choice and plan to upgrade to them later ( budget right now won't allow it ).
Also will the 302 Victor JR intake work with the GT40P heads when I do get to upgrade?
giddyup306
3,041
Sep 14, 2004
  • Sep 14, 2004
I'd personally ditch the stock 302 heads. Keep in mind they are designed for a 302 not a 342. Also it really isn't designed with performance in mind. Yes your intake will work with the other heads. Also I'd look into some screw in style studs. Especially if you want to run a high lift cam or high rpms.
G
gasngo
  • Sep 14, 2004
That's what I was thinking but didn't want to admit it. Boy, is the wife gona hollar when I tell her I gotta fork out another $600.00 for my little toy . Thanks for the reply.
extozy
93
Longview, TX
Sep 14, 2004
  • Sep 14, 2004
lol, your wife hollars..?
TT91
1,536
Paramus, NJ
Sep 14, 2004
  • Sep 14, 2004
Dont waste the money on a forged crank when a cast steel crank can hold any amount of HP within the stock block range. Cast steel crank are fine to 700-800 flywheel hp, when your combo needs a forged crank, your talking 4 digit numbers. Take the few hundred dollars your saving from the forged to cast crank and throw it into some nice heads. If your not paying upwards of 800-900$ on a forged crank, then its either not forged, or a peice of crap.
giddyup306
3,041
Sep 15, 2004
  • Sep 15, 2004
Ditto. My 347 has 700 GHP (guesstimated hp) and all it has is a cast Scat crank. It's fairly light weigh too. I think I paid like $200 for it. Just make sure it goes through a lot of heat cycles before you twist your car @ high rpm's.
BTW you don't need to tell the wife about your performance parts
TT91
1,536
Paramus, NJ
Sep 15, 2004
  • Sep 15, 2004
just me again, go nothing less then afr 185s..
bmorrisj
449
Buena Park, CA
Sep 15, 2004
  • Sep 15, 2004
how about some ported windsor sr. heads (200cc) for ~$600....
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
M
Engine 302 Build Question
  • Middleagecrisis
  • Oct 22, 2020
2K
Fox 5.0 Mustang Tech Oct 24, 2020
Middleagecrisis
M
A
1991 5.0 - fires up every time, idles perfectly, but once it’s warm it won’t idle for more than 15 seconds
  • Jul 27, 2021
  • 2 3
9K
Fox 5.0 Mustang Tech May 21, 2022
Mindseye007
Back On The Forums
  • schwifty
  • Oct 12, 2017
  • The Welcome Wagon
The Welcome Wagon Oct 15, 2017
Davedacarpainter
