347 Stroker, How to verify?
l3lue
32
I recently bought a mustang that the previous owner claimed was a 347 stroker...is there anyway to verify this without completely tearing the motor down and measuring everything? I was thinking with a gauge and measure cylinder volume? how can i verify this?
That is a tough one. What kind of heads/intake are on the car? That could be an indication. Me personally, I would go snake one of those long Slurpee straws and stick it down in the spark plug hole and roughly measure piston travel with it. Of course, that wouldn't exactly be very definitive. But it sure would be redneck engineering at it's best.
The balancer should say 28oz somewhere on it. Thats at least an indication that its a stroker.
That will only tell you that it's been rebuilt/rebalanced. It will not offer a clue as to the displacement.
The method mentioned above about measuring the piston travel seems pretty reasonable. It will at least give you an idea of the crank stroke. A dial indicator would be the ticket!
Just ask him to tell you who built the engine and when. Call and verify what he says and if he can't at least show you a receipt from the rotating assembly or machine work I wouldn't believe him. Unless of course he claims he bought the car with the 347 already in it....
I personally always keep my receipts from engine builds and most people I know do the same.
fill cylinder w/ oil
If you really need to know, take a syringe or other measurable dispenser and with the #1 cylinder down fill it with oil.
Then turn the motor by hand a few times to clear the cylinder and once its mostly clear, I'd hit the starter a few times with the plug still out.
Next with #1 up, repeat. Compare the difference (subtract up from down) in volume it took to fill it.
The difference in engines is only 3 oz so you'll have to be careful to be exact as possible.
302 = 20.89 oz. per cylinder
617.79 ml
347 = 24.03 oz per cylinder
710 ml
Just an idea from an engineering perspective.
jballa - I imagine if he doesn't 'own' the car yet, the current owner is probably not going to like that idea;)
Now be very careful of someone saying that have a stroker because to most it would be difficult to tell. I had a friend that was told this and it ended up being a 302 upon teardown.
A few tips as alluded too:
Check piston travel from TDC to BDC by pulling out spark plug on #1 cylinder (passenger/front towards radiator) and useing a clothes hanger or similar and turn the engine over by the harmonic balancer bolt. If it measures 3.4" (roughly) from TDC to BDC you have a 3.4" stroke which is the 347.
3.0" stroke is a 302 for your info, so you do have a little room for error but only about .4":)
Checking the balancer is a good 'additional' way to confirm the previous step. If it is aftermarket and says 28 or 0*, that is an even better indication.
When most rebuild the engine they typically keep the stock balance of 50*, which usually ends up keeping the stock balancer style.
If you are familiar with the power of the 5.0L and how it feels you could test drive...but the seat of the pants can be deceiving.
Also looking for aftermarket heads/cam (sound/behavior)/intake is a good indication as well to help further the 'piston travel' step.
Good Luck!
