347 stroker question
  • Thread starter Thread starter 1967coupe04
  • Start date Start date Nov 29, 2005
1967coupe04
  • Nov 29, 2005
I have a 1983 302 block that is bored .30 over and I was wonding if any kind of machining or modifications would have to be done to the block to build a 347 stroker any help would be appreciated thanks.
89white50
440
central MA
Nov 29, 2005
  • Nov 29, 2005
need to clearance the skirts.
troyGT03
278
too close to memphis,tn
Nov 29, 2005
  • Nov 29, 2005
there is some grinding to the bottoms of the cylinder jugs to make clearance for the longer throw of the crank. not too much, just enough for the crank weights and rods to make their way around.
1967coupe04
  • Nov 29, 2005
Thanks for the info, is the grinding that needs to be done something that i could easily do myself or will it need to be done at a machine shop?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 29, 2005
  • Nov 29, 2005
many peeps do it themselves with a die grinder.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Nov 29, 2005
  • Nov 29, 2005
Its the cranks throws?
In the 351W's,its usualy the connecting rod bolts.
But which ever it is its pretty easy,getting a good bit really helps.And take your time,and make it look good,you'll have no prblems.
1967coupe04
  • Nov 30, 2005
Sounds pretty easy, Thanks a lot for all your help everybody.
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
