  • 1994 - 1995 Specific Tech
347 won't fire
  • Thread starter Thread starter 95riosnake
  • Start date Start date Jan 22, 2011
95riosnake
630
Pittsburgh, PA
Jan 22, 2011
  • Jan 22, 2011
Ok so about a month and a half ago I was hanging some fluorescent lights in my garage so I pulled the cobra out into the driveway. It started effortlessly as always. It sat out for about 4 hours and when I went to pull it back in, it wouldn't fire. We ended up having to push it back in (not an easy task with a sloped driveway...) It was in the 30s that day, I have no idea how cold could have caused this problem but I'm running out of ideas.
It is getting fuel (you can smell it coming out of the exhaust when it is cranking) and cranks fine. I did a lot of online research and found that it was most likely one of two things: the distributor or the TFI module. I first replaced the distributor with a brand new Accel BilliTech, the car still wouldn't fire. I just put in a new TFI module, and still no go.
The car has a brand new MSD coil, new Taylor wires, and new spark plugs. I also replaced the CCRM module this past summer when it wasn't kicking the cooling fan on.
I am completely out of ideas as to what is wrong with this thing. This motor has less than 1000 miles on it, EVERYTHING is new, the only reused things were the alternator and the distributor (which is now replaced). Any help is appreciated. I'd love to get the codes scanned but I can't exactly get it to anyone with a scan tool. I don't want to keep just throwing parts at it.
HISSIN50
34
129
Jan 22, 2011
  • Jan 22, 2011
Dan, any codes? Do you have spark, injector pulsing and fuel pressure?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
Jan 22, 2011
  • Jan 22, 2011
I've had that happen before. In my case it was the ignition coil. Just hook a timing light up to a wire and see if you are getting any ignition for starts.
Kurt
D
Daves94vert
113
Jan 22, 2011
  • Jan 22, 2011
Dit you try flooring it while cranking?
95riosnake
630
Pittsburgh, PA
Jan 24, 2011
  • Jan 24, 2011
I don't have a way to pull the codes unfortunately. When I rotate the dizzy with the key on, I can hear the injectors cycle, so I am guessing I have injector pulsing (I'm thinking this would mean the dizzy is good also?). I picked up a fuel pressure gauge to hook up tonight and see what kind of fuel pressure I'm seeing at the rail.
Kurt
I checked the ignition coil by holding the coil wire up off the center pole of the cap while we cranked the car, no arc... so I put the stock coil on and did the same, no arc again. This leads me to believe the coil isn't getting power?
Yea a few times and no luck.
I'm going to try and locate a CCRM locally to swap on to see if that is the problem. If it isn't the CCRM then I'm not sure what the issue is.
Other things I have eliminated:
Tried both the stock and Accel distributors, neither fix the problem.
Tried stock and replacement TFI, neither fix the problem.
Put in a new set of plugs, didn't fix the problem.
Checked ground strap to timing cover, good contact on both ends.
HISSIN50
34
129
Jan 24, 2011
  • Jan 24, 2011
Hold off on the CCRM swap.
Put a test light across the two coil terminals (the small electrical wires that plug into the coil) and see if the test light flashes while cranking.
If not, check for constant 12V at the + side of the coil (assuming you don't have a box).
You can pull codes with a jumper wire if you like. A paperclip is all you need.
95riosnake
630
Pittsburgh, PA
Jan 28, 2011
  • Jan 28, 2011
Well it's been a long week with some long hours at work so I had zero time to cuss at the mustang until today. I did accomplish a couple things.
Tested fuel pressure and I'm seeing 38 at the rail.
Did the paperclip trick and pulled codes, I got:
52 - Power steering pressure switch circuit open
52 - Power steering pressure switch always open or closed
and what I believe is a code 133? no idea what that is. It took me several tries to get the codes because it's a bit difficult to read CEL flashes.
I am picking up a test light tonight to hopefully diagnose the coil properly.
Going to pull my computer because since I have an SCT chip, it has an LED that is supposed to flash once when you turn the key to the on position. If it doesn't flash, apparently you've got a problem. It could be as simple as a bad ground or 12v connection to the PCM...or i could even need a new one, who knows.
HISSIN50
34
129
Jan 28, 2011
  • Jan 28, 2011
Dan, it is a pain to try and count those flashes. FWIW, if you have the stock EEC, you should have 3-digit codes.
If funds allow, you might wanna grab an LCD [display] code reader (30 bucks or so). It's a nice thing to have in the toolbox.
95riosnake
630
Pittsburgh, PA
Jan 28, 2011
  • Jan 28, 2011
Hmm, so do you mean the two 52 codes are incorrect and should be 3 digit? Maybe I should pick up the digital unit then, haha.
HISSIN50
34
129
Jan 29, 2011
#10
  • Jan 29, 2011
  • #10
Yeah, we should be seeing the triple digit codes. If you had a PIH swap or something, then the 2 digit codes would be appropriate.
Knowing the codes might not help in this instance, but having a reader might help down the line. This one is pretty user-friendly (available at many local parts stores):
Equus - Digital Ford Code Reader (3145)
95riosnake
630
Pittsburgh, PA
Feb 4, 2011
#11
  • Feb 4, 2011
  • #11
I finally got some time to play around with the car, and picked up that exact tester (really easy to use BTW).
Here are the codes I got:
511 - Read Only Memory (ROM) Test Failure
111 - System PASS
Not sure what either means. Not sure if when they say "PASS" they literally mean pass, as in the system checked out fine?
HISSIN50
34
129
Feb 4, 2011
#12
  • Feb 4, 2011
  • #12
You have a chip, right?
It's good to know that nothing big was logged.
I'd go back to the coil testing with a test light.
95riosnake
630
Pittsburgh, PA
Feb 5, 2011
#13
  • Feb 5, 2011
  • #13
Yes I have an SCT tune, I think that's the cause of the 511 code.
My friend is a technician, he's coming over before the superbowl tomorrow to go through the car with a fine toothed comb. He does this stuff everyday so there's a good chance I might get this thing figured out.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
