Note: bores beyond 4.03 on a stock Ford block shouldn't be attempted unless the cylinder walls have been ultrasonically tested and have enough meat for the overbore; many of the aftermarket blocks such as the "Dark" block mentioned above (this is probably the "Dart" block) have more meat allowing larger bores.
302 bored .030 over is 4.03 bore X 3.00 stroke = 306.13 ~ 306
302 bored .040 over is 4.04 bore X 3.00 stroke = 307.65 ~ 308
302 bored .060 over is 4.06 bore X 3.00 stroke = 310.70 ~ 311
302 with 3.25" stroker crank is 4.00 bore X 3.25 stroke = 326.73 ~ 327
302 with 3.25" stroker crank and .030 overbore is 4.03 X 3.25 = 331.64 ~ 331 (actually we should call this a 332, but everyone refers to it as a 331; if we're gonna call it a 331 we should start calling our stock engines a 301
302 with 3.25 stroker crank and .040 overbore is 4.04X3.25 = 333.29 ~ 333
302 with 3.25 stroker crank and .060 overbore is 4.06X3.25 = 336.60 ~ 337
302 with 3.4 stroker crank is 4.00X3.4 = 341.80 ~ 342
302 with 3.4 stroker crank and .030 overbore is 4.03X3.4 = 346.95 ~ 347
302 with 3.4 stroker crank and .040 overbore is 4.04X3.4 = 348.67 ~ 349
302 with 3.4 stroker crank and .060 overbore is 4.06X3.4 = 352.14 ~ 352
Let's start it here guys - from now on we refer to a 332 as a 332 instead of a 331. Whadya say?
