351 Cleveland or Windsor...How can I tell?
bkshaw
31
Salem, Oregon
How can I tell of my engine is a 351 Cleveland or Windsor?
I always thought that the Cleveland was a small block and the Windor was a big block...is that true?
Here is my data plate info:
model year: 1972
built at: Dearborn (Dearborn, MI)
bodystyle: Hardtop
engine: 351 CID - 2V "Cleveland" (some "Windsor" units)
consecutive #: xxxxxx
body series: Hardtop - standard trim group
scheduled assy.: May 05, 1972
exterior color: "White"
interior trim: ("Sprint" Trim) Blue cloth w/ White and Vermilion appointments ["White" paint, only]
sales office (DSO): Seattle, WA ("SE")
axle ratio: 2.75:1 "conventional"
transmission: "FMX" automatic
Quick ID
351 Windsor
5-bolt straight valve covers
radiator hose to the intake manifold
regular 5/8" spark plugs
351 Cleveland
8 bolt 2-plane valve covers
radiator hose does not connect to intake
small 14mm spark plugs
One way to spot a 351C is the thermostat housing that bolts to the block intead of the intake manifold. Another is the exhaust ports terminate out past the valve cover surface. Post a pic if you're able, then we can I.D. what you have right away.
EDIT: Heres an easy one: the Cleveland has 8 valve cover bolts while a Windsor only has 5.
Hack said:
The cleveland isn't a big block, but it has larger heads, so it is wider than the windsor. They both share the small block bellhousing pattern with the 302.
The 351 cleveland heads will bolt up to a 400 without any mods.
It takes the big block c-6 that makes it a big block.
The C does share the same head design as the M (351/400), but the M has a taller deck height than the C (just over an inch). The M does take the 385 series 429/460 bell housing bolt pattern while ths C uses the small block one due to it's shorter deck height. The C actually has .3" shorter of a deck height than the W (9.2 for the C, 9.5 for the W, 10.297 for the M). It is the heads of the C that push out the dimensional width of it. Otherwise, the C is as much a 'small block' as the W.
You have to have the small block c6 to bolt to the C and the W alike.
The W has 6 valve cover bolts IIRC, the C does have 8.
The timing cover shroud is cast with the block on the C and the t-stat sets into the top face of it.
Only FoMoCo big blocks are the FE and the 385 (Lima) series.
260-289-302-351W = Windsor family
390-427-428 = FE family
351C-400M = 335 family
429-460 = 385 family
So where does the old truck motor (360) fit?
