351 Cleveland or Windsor...How can I tell?
bkshaw
31
Salem, Oregon
How can I tell of my engine is a 351 Cleveland or Windsor?
I always thought that the Cleveland was a small block and the Windor was a big block...is that true?
Here is my data plate info:
model year: 1972
built at: Dearborn (Dearborn, MI)
bodystyle: Hardtop
engine: 351 CID - 2V "Cleveland" (some "Windsor" units)
consecutive #: xxxxxx
body series: Hardtop - standard trim group
scheduled assy.: May 05, 1972
exterior color: "White"
interior trim: ("Sprint" Trim) Blue cloth w/ White and Vermilion appointments ["White" paint, only]
sales office (DSO): Seattle, WA ("SE")
axle ratio: 2.75:1 "conventional"
transmission: "FMX" automatic
Quick ID
351 Windsor
5-bolt straight valve covers
radiator hose to the intake manifold
regular 5/8" spark plugs
351 Cleveland
8 bolt 2-plane valve covers
radiator hose does not connect to intake
small 14mm spark plugs
a.vannoy said:
Its the other way around Windsor is a small block cleveland is the big block.
The cleveland isn't a big block, but it has larger heads, so it is wider than the windsor. They both share the small block bellhousing pattern with the 302.
Reactions: 1 user
One way to spot a 351C is the thermostat housing that bolts to the block intead of the intake manifold. Another is the exhaust ports terminate out past the valve cover surface. Post a pic if you're able, then we can I.D. what you have right away.
EDIT: Heres an easy one: the Cleveland has 8 valve cover bolts while a Windsor only has 5.
The 351 cleveland heads will bolt up to a 400 without any mods.
It takes the big block c-6 that makes it a big block.
The C does share the same head design as the M (351/400), but the M has a taller deck height than the C (just over an inch). The M does take the 385 series 429/460 bell housing bolt pattern while ths C uses the small block one due to it's shorter deck height. The C actually has .3" shorter of a deck height than the W (9.2 for the C, 9.5 for the W, 10.297 for the M). It is the heads of the C that push out the dimensional width of it. Otherwise, the C is as much a 'small block' as the W.
You have to have the small block c6 to bolt to the C and the W alike.
The W has 6 valve cover bolts IIRC, the C does have 8.
The timing cover shroud is cast with the block on the C and the t-stat sets into the top face of it.
