351 efi distibutor?
  • Thread starter Thread starter BK_CAULEY
  • Start date Start date Feb 10, 2007
First Prev 2 of 2
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 19, 2007
#21
  • Feb 19, 2007
  • #21
no problem sir. I was running holley systemax II heads on my 351w and i found out that 165cc intake runners compared to the 210cc intake runners on the vic jrs make a heck of a big deal. Don't buy small heads for a 351w. now i have a set of holley heads just waiting to be installed on my F-150.
302RollinHard
Columbus, OH
Feb 19, 2007
#22
  • Feb 19, 2007
  • #22
you want some end play so the thrust washer will get lubricated. If your oil pump driveshaft is too long it will push that lobe above the gear up into the body of the distributor when you tighten down the distributor retaining bolt. No space means no lube no lube means no worky for long. It completely locked up the shaft. I look at it this way... now I have replacement parts for my new distributor. Yeah that is the last $320 i will give to MSD
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 19, 2007
#23
  • Feb 19, 2007
  • #23
thats never good
yea i might go ahead and trim a little off then. do you think 1/8-3/16 should do it? doesnt sound like much but it could make a difference in oil getting through or not.
302RollinHard
Columbus, OH
Feb 19, 2007
#24
  • Feb 19, 2007
  • #24
well, check things out. If the shaft is seated completely down and the housing isn't seated on the engine block, you need to trim it. Conversely if the housing is completely flush with the block and there is no up and down play in the shaft, you need to trim it. If it needs trimmed, you just hit it with the grinder and re-install and re-check I think mine was about 1/8th that I had to trim from my milodon pump shaft. Just look at the uninstalled distributor and that lobe between the body and the gear and note the distance/amount of play between the lobe and distributor body. You will need that much play in the distributor shaft when installed as well to allow for proper oiling.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Feb 19, 2007
#25
  • Feb 19, 2007
  • #25
gotcha
noted and in my tech article. still waiting for daggar to reply if he wants it in the stickies or not. i think it should be.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 19, 2007
#26
  • Feb 19, 2007
  • #26
I think there must be a difference in the actual body of the two distributors. I believe the 351w have a longer body because of cleaence issues with the intake. The shaft part of the dizzy is the same length from where it mounts onto the block and down to the oil pump but above that i believe the 351w dizzy is about .83 of an inchtaller then the 302 dizzy.
vristang
4,933
101
124
Seattle
Feb 19, 2007
#27
  • Feb 19, 2007
  • #27
BK-
I finally made the long trek to the garage and looked at all 3 of my distributors.
I have the original from my 302, one from a Bronco 351w donor motor, and the 351w dist I had been running in my 408w.
I couldn't tell which was the 302 and which was from the Bronco 351w. They were the same length, both above and below the mounting surface. (I am sure it won't be the last time I am wrong )
The dist I had in the 408w however, used to be longer. I had to trim the length by about .250" IIRC.
It seems the aftermarket pump shafts don't allow the dist to fully seat without trimming.
(All three of the distrubutors I have mentioned would have been the same length, from the factory)
I will modify my 351w article tonight to reflect this.
(with as often as I post that thing, I am a little disappointed this error hasn't been caught before )
thanks for your perseverance.
Keep us posted on your progress
jason
302RollinHard
Columbus, OH
Feb 20, 2007
#28
  • Feb 20, 2007
  • #28
another "mustang myth" busted
Good catch BK.
D
Daggar
3,902
#29
  • Feb 21, 2007
  • #29
-- Thread closed --
Please see BK_Cauley's Tech article for this discussion here:
http://forums.stangnet.com/showthread.php?t=687004
First Prev 2 of 2
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
  • dan50
  • Jul 18, 2026
dan50
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
