  • 1994 - 1995 Specific Tech
351 Windsor Help!
  • Thread starter Thread starter 97windosr
  • Start date Start date Jun 15, 2010
9
97windosr
9
  • Jun 15, 2010
Hey guys I am looking at buying a 97 6 cyl body with a 351 windsor motor that is bored 30 over, w 305 cams and springs, an edelbrock intake mani, shorty headers, SINGLE flowmaster exhaust, and 20" wheels. Now I know roughly what this should put down, and went on a test drive yesterday. It seemed very slow for a 351 windsor. The idle is nice and smooth, which worries me because of the cam it is supposed to have. its not leaking, smoking, overheating etc. Do you think a single exhaust, and 20" chrome wheels will make a huge difference in speed? I don't want to buy it and find out its not a Windsor. I have heard tips of what a Windsor looks like, and how to tell if it is a Windsor. Some of them were that it will have 6 bolts instead of 8 on the valve cover, the air filter will be about an inch above the spot where the distributor goes into the block. Well it has the 6 bolts on the valve cover, the air filter is about an inch above where the distributor mounts to the block. I tested the car yesterday and looking at making a decision today, but need some more advice. The 20's will be off right after I buy it and dumps will be put on lol just so everyone here knows....Thanks for any fast help!
moosetang408w
90
Alberta, Canada
Jun 15, 2010
  • Jun 15, 2010
So if you are trying to see if it is a 351 or a 302 block. I believe there are some differences around where the alternator is for easy identification due to the block height difference. If it was me I would probably look at the intake manifold. There should be a part number and the 302 and 351 are not interchangeable.
KamiKaziDK
555
Mesa, Az
Jun 15, 2010
  • Jun 15, 2010
You said it has single exhaust???? that's already sounding odd, do you mean single chamber flowmaster? and 305 springs and cams?? That's odd sounding too. It could just be a stock 351 with the 302 timing and everything made to work in the car, do you have pictures?
Adam95GT
2,564
Burlington, NJ
Jun 15, 2010
  • Jun 15, 2010
I dont know about that.... the intake base should be wider then a 302... i think its like 11.5'' instead of like 9.5 or something like that
Venom351R
4,548
41
98
MAINE
Jun 15, 2010
  • Jun 15, 2010
302 is a 8.2 deck, the 351 is a 9.5 deck height
Adam95GT
2,564
Burlington, NJ
Jun 15, 2010
  • Jun 15, 2010
hmmm so thats what deck height means
MysteryMachine
1,835
Parkesburg, PA
Jun 19, 2010
  • Jun 19, 2010
Maybe its slower cause it has 2 cams
KamiKaziDK
555
Mesa, Az
Jun 20, 2010
  • Jun 20, 2010
And they're small block chevy cams
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
Jun 20, 2010
  • Jun 20, 2010
Yeah, it's going to be slow. Even if it is a 351, they've pulled it out of a truck, and plummed it through a single exhaust. If it idles smoothly, it has a stock truck cam in it. That quality of the work (given that they plummed it through the stock V6 single exhaust) implicates that the person who installed the engine was talentless, and therefore wouldn't have the tuning ability to make it idle smoothly with a cam. The heads on a 302 and 351 are interchangeable, so there would be 6 bolts on either. I think a 351 cleveland has 8 bolts on the valvecover, but that's a completely different engine all together. I would go with Adam's method of checking whether it is a 302 or a 351, by the distance across the intake. A picture would go a long way too, if you could post one. I have no idea what 305 cams are.
Kurt
moosetang408w
90
Alberta, Canada
Jun 23, 2010
#10
  • Jun 23, 2010
  • #10
If the car has a 351w plumbed through some single exhaust and 20" rims. I would avoid it in the first place. Who knows what the hell ghettoness took place on the swap with the car.
What could have taken place
"oh, **** I need some assembly lube for these bearings or some ****. Oh I will just use the peanut butter from my sandwich. Hellz ya. I am building an engine"
But seriously does the build look as shoty as it sounds?
Venom351R
4,548
41
98
MAINE
Jul 11, 2010
#11
  • Jul 11, 2010
  • #11
the 351 is also 2.5" wider then the 302.
Pokageek
2,767
MA, USA
Jul 13, 2010
#12
  • Jul 13, 2010
  • #12
But remember, a 351W stroked to 414c.i. takes up the SAME space as a 351! :SNSign:
SublimeRT
230
Clarksville, TN
Jul 13, 2010
#13
  • Jul 13, 2010
  • #13
Just to clarify, deck height is the measured distance from crankshaft centerline to the deck of the block, where the heads mount. Not the width of the intake base, if that's what you were thinking.
Venom351R
4,548
41
98
MAINE
Jul 14, 2010
#14
  • Jul 14, 2010
  • #14
yeah and if someone was selling a stroked out 414 from RNH at the same time someone wanted a 351 based engine that would be sweet
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Q
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
