351
jes72mustang
224
S. Central PA
First 351 Windsor or 351 Cleveland?
Different Blocks and parts. Which could start another whole debate.
You will have more power with either (Properly built)
They are bigger and heavier then a 289 or 302.
More parts available for the windsor (which is in the same family of engines as the 302).
rbohm
SN Certified Technician
Apr 12, 2002
6,698
551
204
tucson,az
swapping a 351w or 351c in place of a 289/302,
pros
larger displacement capacity(up to 427ci with the stock block)
more torque capacity
more hp capacity
cons
tighter clearances(requires swap headers)
more weight(unless you use aluminum heads to bring the weight down)
high fuel consumption(if you care about that in this application)
