351w ARP Head Studs for Trick Flow Heads ???
looks like part number 154-4203 is what you want for normal 351w with normal heads
looks like part number 254-4307 is specific to svo heads
" " " " 254-4107 is specific to SVO blocks
" " " " 254-4110 is specific to 1994 Yates heads
" " " " 254-4109 is specific to SVO Yates style heads
" " " " 254-4310 is specific to SVO Block with 94 Yates Heads
Thanks 86 Blue-
I think I will just have to contact ARP later this afternoon.
Summit doesn't describe any kit (that I saw anyway) that is specific to the 351w with TW heads.
I'll post back with what I find out...
jason
If you are installing the TW heads on your stock 351w, Then regular ARP head studs are fine. TW heads come with the 1/2" which is the same as the 351w.
The 302 with Twisted wedge heads, require the use of HeadBolt t washers to reduce the size from 1/2" to 7/16"
Well I finally heard back from ARP on the Head Studs and Main Studs.
The head stud kit I went with is...
http://store.summitracing.com/partdetail.asp?part=ARP-254-4503&autoview=sku
For the main studs I will be using the following kit...
http://store.summitracing.com/partdetail.asp?part=ARP-155-5401&autoview=sku
This kit is for a Ford 460 2 bolt main, but because my main girdle is 1/2" thick this stud kit will work.
The normal 351w main stud kit would not have been long enough for use with the 1/2" main girdle.
