351w carbon backfire
84fiveohore
23
york, pa
:mad: still cant get my 351w right.
still backfireing through carb black carbon... what in the heads could cause this... also i had to grind down the bottom of the rockers on the exhaust rockers cause they were touching the retainers.... i checked the pushrods they are the long ones for the tall deck.. im out of ideas.. any help guys .. thanks
first clue something isnt right...you had to grind down a rocker. how was it touching the retainer? could you better clarify this for us? and have you checked to make sure your timing is right, and you are getting adequite/ correct ignition?
I had to grind down all the exhaust rockers.. they were touching on the pushrod side of the rocker.
we went over the timing 10 times.. the only thing that could be messed up there is, we used one of those adjustable timing chains.. the bottom gear had the notches for +4 , 0 -4 so on and so forth.. im pretty sure its on 0. and its a 302 cam so the firing order is set for the 302.
we have spark, fuel, and we have the car wired for a push button start.
the coild is factory wired from the 86 wiring... pluged in the coil.
but when u start it .. it will run for 5 seconds and backfire black smoke and sometimes we get some fire..
there are different 302 cams. the base 302 and the 302 H.O. which are differnt firing orders. i dont think the car would even run with the H.O. cam and base firing order or vice versa. where did you get the cam or out of what? and what is your current firing order?
edit: you said they where touching the retainers? and as mention above you said you ground then down on the pushrod side, so you obviously arent talking about the spring retainers are you? what retainers are you talking about?
the cam is a crane fireball 2,
correction, i ground the bottom of the rocker that would not be touching the spring when it is bolted to the head.... their 70 d00e heads... between where the rocker is bolted to the head and where it touches the top of the valve is where i ground it down. i hope thats clear enough
i hate to reiterate but did you order the cam from crane/summit/jegs...etc... if so do you have a part #. it is important that you have the right cam for the right firing order as stated above. off the top of your head do you know what firing order you are running.
302 1-5-4-2-6-3-7-8
302 H.O. 1-3-7-2-6-5-4-8
if the cam is not designed for an H.O/ standard its not going to run propperly
its the 1,5,4 firing order.. the cam was givin to me by a friend.. the cam is stamped fireball on it.. he said it came out of a 289.. so im not sure ... but we tried the 351/302 ho firing order and we got nothing.. bluh bluh no firing.
the 15426378 is the order that the car will start on.. but like i said only will run for 5-10 seconds of us givin her gas and BLAM!! big cloud of black ****.. im trying to figure out what to do.. cause at 2pm im headin to my garage to tear the motor down.. if i dont have to (gaskets aint cheap) i dont want to..
thanks
i know you said you have been through the timing, but once more do it again. this problem is sounding more and more like a timing issue. just make sure the #1 is top dead center on the compression stroke not the exhaust stroke. (180 degree's off) and make sure the rotor is pointing directly at #1 on the cap (it should be marked). im pretty sure you know this, but it doesnt hurt to hear it again. just trying to help not preach.
i hear ya.. its been tough.. the only thing that could be wrong with the timing is that adjustable crank gear,+4,0-4 if it was wrong how would i fix it with out pulling the timing cover. and the engine is tdc, and the rotor is on number 1. its a shame to the motor and trans just slipped right in the car.. no issues.. figures somthing else had to go wrong. thanks man ..
if you have an adjustable cam gear the only way to correct it is to pull the cover and set it. but it being 4 degree's off isn't enough to make it not run. and you cant correct cam timing with the distributor because cam timing adjust how soon or late the valves open, not when it fires. other than setting/correcting timing and making sure you are getting adequite and correct fuel im at aloss with this one. maybe someone else with a similar problem or more insite on the subject can step in with an answer.
