351w Rod Pins?
A floating piston which the rod has a bushing so the pin floats has much less friction. less friction more horsepower. The bushed rod and piston combo also has less side load on the cylinder walls.
Yep the floating ones are stronger and more efficient. You could coat them with a low friction coating I would assume too, although there may be too much pressure on their surface for the coating to handle, so you might not be able to. If you could, it would give you an even more efficient junction.
""Another benefit to floating pins----- if the pin happens to seeze in either the piston or rod bushing, it may still pivot in whichever location it's not seezed ( ie : the rod or piston)""
LOL... if any part of my rod bushing is seizing, I think I would want to know about it right away!!!
Seriously, I think pressed is fine for most street applications....
I am pretty sure you will know right away because you will most likely do some major damage, on the other hand if you have a foating set up and it does happen to sieze you are less prone to damage. If I am correct the floating set up was designed for racing applications and high rpm durability
