351w swap need help will not idle
mustangpauly
10
wisconsin
i need!!!!! Help my 302 tune is not work im just lost.
  • 351w startup tune.msq
  • 351w startup1.mlg
  • Sponsors(?)
mustangpauly
10
wisconsin
351w stock short block with gt40p heads and f303 cam, 70mm tb. speed master intake, 19 lb. injector and a 255 fuel pump.it will not idle on its own and when warm it hunts. im trying to get some run time on the new motor before i put the turbo kit on.
mustangpauly
10
wisconsin
i had it run with the stock computer but it was running lean. i know i need bigger injectors, i was hoping with megasquirt to make it work im not looking for WOT
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,677
5,854
204
31
Hillsborough county
The f cam is not very aggressive, I have not had time to look the tune over yet but it should idle relatively steady with the timing locked at 15* and the idle valve in a set position.
