351w Swap - Wiring Help!
Ok im doin the 351 swap in the 4 cylinder mustang. After i got the 4 banger pulled from the car, there is soooo many wires, that seem useless now. BTW im converting to CARB, so im pretty sure alot of these are useless to me. A friend told me that the huge bundle of wires that are coming out the passenger side of the car can be cut off, that i wont need any of them. And he says keep the ones on the driver side because those are you headlights etc. I dont want to cut these wires if i will be cuttin the AC or something else that i will want on my new engine, I will be running power steering, AC, and power brakes. Thanks for the help guys.
-AJ
Is your friend dumb? he's probably at home doing this>:bang: I mean those wires connect into the dash wiring the a/c etc dont cut them figure out which ones you dont need and tape them up dont cut them
This is some of the best advise you will get. Take it.
I got this data from http://www.jason.fletcher.net/tech/efi-carb/efi-carb.htm
Once you've got everything out, it's time to start re-wiring. All the re-wiring will take place at the two connectors by the brake booster that you unhooked earlier. This is how you will tap into the chassis harness and get things like the fuel pump working again. Best way to accomplish this is to tap into the wires just below the connectors. I use those little plastic splice connectors...works great. Be sure to tape up the open ends of the connectors to prevent water from getting in there.
If you've got a Chiltons with the wiring diagrams in it, I will include the reference numbers for each wire if you'd like to look them up.
On the Gray Harness:
---Wire #16 (red/light green - 16 Ga) to the ignition trigger/turn-on lead. On my MSD it's the thinner red wire.
---Wire #11 (Dark Green/Yellow - 20 Ga) to the negative side of coil or the "tach out" port on an MSD. This is the line to your stock tach.
On the Black Harness:
----GROUND #97 (tan/light green - 18ga) to a suitable chassis ground. This creates the ground for the primary side of the fuel pump relay.
---Wire #39 (red/white 20ga) to the temp sender.
---Wire #31 (white/red 20ga) to the oil pressure sender.
---Wire #361 (red 16ga) to #16 (the wire you ran to the ignition turn-on above). This creates the positive voltage supply for the primary side of the fuel pump relay.
My car already had A/C delete, so I didn't mess with the WOT cut-off. Only other thing that you need to do is when wiring in the fuel pump itself. Just get the polarity right on the two wires that are coming off the stock EFI pump. I cut them and extended them out to where my Holley Blue is.
I am following this as I put a carb'd 351W into my 87 LX and it has been spot on with wire numbers and colors.
If you want to do the job right, then pull out all the harnesses that you will not be using, instead of cutting wires individually.
You may be able to recover some of your $$$ by putting some wire harnesses on ebay. No one will buy hacked up harnesses though.
A wiring diagram will help you alot at this stage. A Chiltons should do.
Good Luck,
jason
Just be sure to find something that covers the year of Mustang you are working with.
Hopefully it will also cover a year or 2 before and after your year, as sometimes Ford made wiring harness changes a few months before the model year changed.
My 90GT is wired like a 91. :bang:
jason
I started working on the wiring today, i got all the wires seperated so i can figure out what is what... I got a question though, im kinda confused. I looked at the plug that plugs into my 2.3L AC compressor and wire colors are: black/yellow and gray/white, i followed those wires all the way into the firewall inside the car, and they going straight into the big ECU harness thats connects to the ECU computer thing, my question is why would the AC be on the ECU shouldnt it run into the dash or summin... I think the wires that are going into the harness are pins: 47 and 10... Could someone check those pins for me cuz i cant seem to find a good pinout diagram andwhere... Thanks guys.
-AJ
Many computers use a sense lead to tell if the A/C is on so it will speed up the idle & not stall.
Check out the AutoZone wiring diagrams. They are very good, but don't always include all the body wiring.
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
Ok well i figured out that the plug that plugs into the Compressor doesnt go into the firewall it goes into some other plug, that i dont know what it does.... Im gonna go snap some pics of the remaining parts that i need to identify before i can pull anymore stuff... Pics will be in like 5 mins so check back, thanks./
-AJ
Ok i got rid of the my problems, i have decided not to run AC on this car, its not gonna be driven everyday so it not a problem... I got lots of stuff ripped out of the car now, im gonna be pullin the dash (if i have to, havnt looked yet) so i can pull out all the extra heater cores and all that other AC and Heater stuff, so i can lose some more weight. i had a huge pile of stuff i pulled off the car just rom today, i bet it all weight lik 50 lbs. Here are some pictures of the progress.
This picture was taken before i decided on i wasnt keeping the AC
This is after i decided to get rid of the AC, the pile grew, by ALOT, lol....
Here's the engine bay after all the pullin of the parts, i need to clean it now
-AJ Newman
