351W to 408 Stroker owners...step inside
  • Thread starter Thread starter js66coupe
  • Start date Start date Mar 13, 2010
J
js66coupe
49
Florida
Mar 13, 2010
  • Mar 13, 2010
I have a couple of questions on this.
Whose rotating assembly are you using? And what do you think of Eagle assemblies?
What CR are you running? Looking at Eagle assemblies, looks like they have a -28cc dished piston and a -19 dished cc piston. That would place me at about 9.8CR or 10.8CR. I'm thinking a custom cam with a 10.8 CR might run really well.
robo
132
cleveland ohio
Mar 13, 2010
  • Mar 13, 2010
i have a 347 stroker so i'm not much help on the 408 kits but i would definitely build it with the 10.8 (if not a bit more) compression if you are going to be naturally aspirated.
jasonn
316
By Rochester MN
Mar 15, 2010
  • Mar 15, 2010
Scat and Eagle are both very good. Only thing I have heard about the eagle stuff is it may be a tad harder to balance and the finish might not be quite as good. But only a few have said that. Built a big block with eagle stuff and it was nice. I wouldn't be afraid to use one again at all. Best price I could find was adperformance.com. Scat assembly, probe pistons, with vic jr 60c heads I have just over 10-1. Definately go custom cam! Do NOT go with a ots cam here. For a little bit of money, it is REALLY worth it. I have had very good luck with Ed at FTI on the hyd roller stuff. I am currently switching over though to a CI solid roller. Can't wait.
M
mustangbrad
127
  • Mar 15, 2010
I got mine from ford strokers, which is a Coast High Performance kit. Custom cam from Jay Allen (highly recomend him), 10.4:1 compression. Jay actually set up my entire top end: heads, cam, intake, and valve trane. it will scream if done right. I would lean toward Scat instead of Eagle out of those two.
blown65
1,938
Queen Creek Arizona
Mar 15, 2010
  • Mar 15, 2010
Ditto whats been said, go scat over Eagle. Not much of a price difference. You can also check out Probe Industries stuff.
We did Flat tops on ours with AFR 205's.
H
htwheelz67
444
mission viejo ca.
Mar 15, 2010
  • Mar 15, 2010
scat is the best in my opinion, I got my 408 kit from AD performance, balanced perfectly, fit and finish was perfect and I only needed to clearance the oil pump slightly to clear the crank. Pistons in the kit were probe, high quality bearings and rings too.
blown65
1,938
Queen Creek Arizona
Mar 15, 2010
  • Mar 15, 2010
Scat was good for my engine also, its what I run in my 65 also. Was send as a zero balance crank, but still took quite a bit of heavy metal to balance.
C
Clevorguy
53
San Diego, CA
Mar 20, 2010
  • Mar 20, 2010
I really don't think there is a best, or to say a clear cut winner between the two. The amount of scat and eagle out there is enormous. I would put more research and consideration on who builds it. Obviously both can me made to last a long time.
J
js66coupe
49
Florida
Mar 21, 2010
  • Mar 21, 2010
Thanks for all the responses. Also looks like I should check out AD Performance.
Wildbill3
57
#10
  • Mar 26, 2010
  • #10
Crower 408
I Buy US. products when availible but the price difference is HUGE we did a 408 $$$ with a Crower highend rotating asembly hows that song go Hurts ssoooo good,well If ther is a best this is it Cup quality Cup price also :Track: purpose built for tons of track time no worries here If we sell the FFR were putting it in the 66 stang with the Tko6oo should be a hooot..Have fun Bill
65coupe408w
192
#11
  • Mar 26, 2010
  • #11
I am running SCAT internals in my 408w, SCAT is the way to go. low compression though 9.5:1 (waiting to add the blower), I also have a custom grind cam. It seems to do the trick! car weighs right around 2750lbs without me in it!
65coupe408w
192
#12
  • Mar 26, 2010
  • #12
car...
motor...I have made some changes since this picture
added cooling...
65coupe408w
192
#13
  • Mar 26, 2010
  • #13
I will post some more updated pictures once I finish up my rearend install....
Wildbill3
57
#14
  • Mar 26, 2010
  • #14
65 Coupe I like that Radiater who's is it? Is it a double pass Radiater?
65coupe408w
192
#15
  • Mar 27, 2010
  • #15
The radiator is a dual core universal one from Summit Racing. It just squeezes between the frame rails. But no more over heating problems!
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
