35k service?
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
i just hit 35k miles. what are some recommended maintenence issues? i was thinking new plugs. what kind would last the longest? i also need to do a brake job. i just had he coolant flushed ~15k miles ago and just changed the tranny fluid ~5k miles ago. so what kind of plugs should i get and what else needs to be done?
Did you do everything at 30K, that is the first biggie? This is the maintenance schedule from Ford for my GT. Yours might differ slightly as mine is a 2001, with an automatic transmission.
Present Service: 30,000 Miles
* Change automatic transmission fluid
* Change engine oil and replace oil filter (Up to 5 qts of motor oil)
* Inspect and lubricate steering linkage, ball joints, suspension and, if equipped, half shafts drive shaft and u-joints
* Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system
* Inspect complete exhaust system and heat shields
* Inspect engine cooling system and hoses
* Inspect wheel ends for end play and noise
* Perform multi-point inspection
* Replace engine air filter
* Replace fuel filter
* Rotate tires for optimal tire life
Next Service: 35,000 Miles
I would do oil, tranny, rearend, coolant. and change belt(since they are 2 min job to do), and while belt is off, check for pully noise(mine had noise in it).
I don't think u need to change sparkplug. u can ofcourse if u like.
thats what i did when my car was at 35000
i forgot to mention that the rearend fluid was changed at ~12k miles. so it should be ok. im gonna look at my belt and see if it needs to be replaced. so no one would recommend changing the plugs? ive always heard to change the plugs at 30k miles for optimum performance. :shrug:
mity2 said:
Oh ya that. I forgot to mention that. I need to do mine as well. But I can't find Ford Fuel snap tool thingie..
I got one at the local auto parts store for under $10 I think. Came with two ends for different sized fuel lines. I believe our cars require a 5/16" spring lock release tool.
yeah buy the generic one it's cheaper. and if the line does not want too come off push the line towards the filter and then insert the tool. pushing the line in as far as it goes makes sure the ears and not wedged against the lip on the line. so it will be easier for the tool too work.
and if it still sticks and wont come off, get some wd-40 or pb blaster and let it sit for a few..
im going to be changing my brake fluid when i decide what to do about my brakes. i think im going w/ 13" cobra setup. thanks for all the replies, i forgot about my fuel filter as well.
