  • SN95 4.6L Mustang Tech
3650 grinds into 1st
  • Thread starter Thread starter CobraMaverick
  • Start date Start date Dec 15, 2011
C
CobraMaverick
  • Dec 15, 2011
So, I have a 2001 4.6 Dohc with the Tremec 3650 5spd trans in a 1972 Maverick Grabber
I have looked all over the Mustang forum boards for someone posting about my problem.... no luck. So I figure someone here will steer me in the right direction.
When coming up to a stop around 1 or 2 mph I can no longer get it into 1st gear without grinding it and forcing it in gear. This problem came on suddenly... no warning that something was starting to go bad.
So far all I have done is a fluid change which did nothing for my 1st gear problem but made the rest of the gears shift more smoothly.
One thing I did to try, is to to rule out a clutch problem. I roll forward about 5 mph then depress clutch pedal and shift into reverse.... well, it shifts smoothly into reverse. So I am thinking a Trans problem and not a clutch problem. I have a firm clutch pedal and it shifts smooth as silk into all gears except 1st
2vNotch
519
21
29
Rogers, AR
Dec 15, 2011
  • Dec 15, 2011
mine does the same except for fourth! synchro ???
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
