3G alternator conv. plug
While looking on 50resto.com today, I discovered an adapter plug that changes the 3G alternator's output into a plug that just plugs into the 2G harness. It is found at http://secure.50resto.com/category.cfm?SID=1&Category_ID=575
I'm about to do the conversion myself, and I was wondering if this would be a good idea. It doesn't replace the power wire, right? So I can still upgrade that. Has anybody else used this? Any thoughts?
You are going to push 130 amps down wiring that is only supposed to carry 65 amps? Do you smell the smoke and see the flames yet? :bang: :bang: :bang:
You need a 4 guage wire and a fuse rated at 125-150 amps to carry the current without risk to your fine machine.
See Here's websites with pictures of the 3G installation procedure...
See http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm - all the tech data you could ever want to know
OR
http://www.fordmuscle.com/archives/2001/03/paperformance/index2.shtml
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
For the right way to do the wiring. Some people will tell you that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in the wiring harness is ugly and expensive.
Those are all excellent links to the 3g upgrade...personally I got everything I needed from the junkyard and the 4AWG wiring from my local Home Depot for I think .19 a foot or something like that...whole thing including j/yard alt cost me less than $30 and thats including a Taurus fan....been running fine since early summer...
:shrug: Just curious, how does that Taurus fan work out? Will it bolt up directly to the radiator or does it have to be modified? Also, do you have a/c and how well does it cool the temp?
Thanks :nice:
