I pulled out an 3G alternator I had purchased a few months ago to install it. When I got to looking at my stock wiring I discovered that I dont have the white/black wire you are supposed to cut and splice the new plug on to. I suspect the previous owner did something funny here as I've found a bunch of wiring problems on the car.
Regardless I need to know what to do about this wire. From looking at the wiring diagrams at the links below I think the wire goes from the voltage regulator plug you keep from your old wiring. Should that plug have a grn/red, yellow/white and the white/blk wire? Mine only has the first two, the third slot is plugged with silicon.
So do I need to run a wire from that extra slot on the old plug to the new plug that the 2G alternators don't have?
For the Fox 5.0
For the 94-95
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
For the Fox 5.0
For the 94-95
