3G alternator needs a new bracket?
  • Thread starter Thread starter PhLoBuS
  • Start date Start date Nov 22, 2004
  • 3
1 of 3 Next Last
PhLoBuS
473
Beverly, MA
Nov 22, 2004
  • Nov 22, 2004
I am about to order a 3G alternator with at least 150AMPS. Where is a good place to buy one (I checked ebay) and also whats this about needing a different alternator bracket? If so where can I grab one?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 22, 2004
  • Nov 22, 2004
Nope...you don't need a new bracket...you grind off an inside corner on your bracket...you will see where and how much it is when you try to put the 3g alternator in and try to align the two bolts...it is like 1 inch of total area...I just got out my grinder and ground on it for a bit and all was well...fits and works nicely
L
leakyfaucet
273
North Carolina
Nov 22, 2004
  • Nov 22, 2004
Yep I did the same thing. I grinded with a drill and I went through about 3 stones before it was all done. It was easy.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 22, 2004
  • Nov 22, 2004
I used one of those handheld grinders and nothing wore out on it...of course the I put on safety glasses...those little pieces aren't good for the eye ...they are pretty cheap but they can tear somethings up for their size...
L
leakyfaucet
273
North Carolina
Nov 22, 2004
  • Nov 22, 2004
My electric drill kept running out of batteries too. It took me like 2 hours to grind everything away.
Man, do I need better tools.
PhLoBuS
473
Beverly, MA
Nov 22, 2004
  • Nov 22, 2004
lol alright thats no biggie then... where is a good place I could find a 150AMP+ one?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 22, 2004
  • Nov 22, 2004
It took me about a minute...This was a plug-in appliance
L
leakyfaucet
273
North Carolina
Nov 22, 2004
  • Nov 22, 2004
Lucky ß@$+@®Ð
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 22, 2004
  • Nov 22, 2004
Well I don't know about 150amps but a 130amp would be enough for you and a nice replacement over stock...
www.paperformance.com is where I got mine from...it is a little pricey with the Alternator and the 4g wire upgrade kit but it comes with everything you need and color instructions (includes where to shave the bracket at)...it even comes with zipties
L
leakyfaucet
273
North Carolina
Nov 22, 2004
#10
  • Nov 22, 2004
  • #10
I got mine off ebay. It's used, but still works perfectly. I got it with the wires for ~$70
PhLoBuS
473
Beverly, MA
Nov 22, 2004
#11
  • Nov 22, 2004
  • #11
Alright I guess I will go with a 130amp, I need the 4G wire kit? I thought it was a 3g...
PhLoBuS
473
Beverly, MA
Nov 22, 2004
#12
  • Nov 22, 2004
  • #12
http://cgi.ebay.com/ebaymotors/ws/e...em=7936204639&category=33573#ebayphotohosting
150Amp ^
That would work fine correct?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 22, 2004
#13
  • Nov 22, 2004
  • #13
The 3g and 4g are referring to different points in my thread...sorry I didn't clarify...the "4g" is a form of measurement on the amp-load (I believe) and thickness (which kind of go hand in hand) of the actual wire...for example 10guage wire (10g) would be skinnier than the 4guage (4g) wire...
The bigger wire will help prevent any underhood fires because of the "old" wires not being able to handle the new power from the "3g alternator"...I'm not exactly sure why the alternator is called a "3g"...?
PhLoBuS
473
Beverly, MA
Nov 22, 2004
#14
  • Nov 22, 2004
  • #14
Would that link I put from ebay up above be a good choice?
L
leakyfaucet
273
North Carolina
Nov 22, 2004
#15
  • Nov 22, 2004
  • #15
Looks fine to me. You'll need all of that stuff they show in the picture. The only bit of that stuff that you can't find at a local stores is the white stator wire. It doesn't say that it comes with that. I would e-mail them first to find out.
Usually in car terms, the G in 3G means 3rd generation. I guess that's the 3rd major design in alternators for mustangs?
Okay, now that I helped you, could you turn your key to the ON position (assuming your car is cold) and feel your oxygen sensors after ten minutes. Are they warm?
PhLoBuS
473
Beverly, MA
Nov 22, 2004
#16
  • Nov 22, 2004
  • #16
bmorrisj
449
Buena Park, CA
Nov 22, 2004
#17
  • Nov 22, 2004
  • #17
get a nice 4awg cable, put it to a 200amp fuse and the other end to the solenoid...and if you want to change the bracket and lose the tensioner, march has an alternator tensioner bar that deletes the idler and bracket...
L
leakyfaucet
273
North Carolina
Nov 22, 2004
#18
  • Nov 22, 2004
  • #18
No, I'm serious. Will you do me this favor? I need to know if the oxygen sensor heaters turn on with the key in the ON position. I haven't been able to get anyone to do this yet.
L
leakyfaucet
273
North Carolina
Nov 22, 2004
#19
  • Nov 22, 2004
  • #19
I would recommend lower than a 200 amp fuse. The reason being the higher the rating the longer it will take to blow even when there is a huge spike.
PhLoBuS
473
Beverly, MA
Nov 22, 2004
#20
  • Nov 22, 2004
  • #20
im going to bed maybe tomorrow I will
  • 3
1 of 3 Next Last
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
J
New to Mustangs/Fords
  • Joradan93Foxbody
  • Mar 2, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 2, 2026
Joradan93Foxbody
J
