3g alternator problem
1991vert
1,103
Ludlow, MA
the nut on the stud fused the nut to the O-connector. it's basically all welded together and never coming off. i pulled the alternator apart thinking i could replace the stud and when i took the cover off, 2 springs popped out and i broke them trying to put them back together. is this fixable? or do i need a new alternator?
My foggy recollection is that I'm thinking you might need a new rectifier. Jrichker, Monte or one of the other alternator gurus can say yes or no to that.
Good luck.
man, once those springs come out they are damn near impossible to put back in. my first suggestion would be to find an alternator or generator shop. they re work a ton of these things and would most likely be a hell of a lot cheaper than buying a new alt.
