3g alternator problems
1990_GT
41
Marysville Wa.
I just swaped a 94-95 GT alternator on my 1990 GT, when I first start the car it puts out 14.5 volts. After about a mile of driving it goes down to about 11, then a little later 10, got it home before it went any lower, this has happened twice now. The alternator tested go 3 times in a row, 3 different times, put a different alternator on and its still doing it. This happened with the stock alternator so thats why I upgraded(thought the alternator was bad) anybody got any ideas? thanks in advance.
Never, never disconnect an alternator from the battery with the engine running. The resulting voltage spike can damage the car's electronics including the alternator.
Check the grounds first:
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
Any car that has a 3G or high output current alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects. The 3G has a 130 amp capacity, so you wire the power side with 4 gauge wire. It stands to reason that the ground side handles just a much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery & extra 3G alternator ground wire as described above in paragraph 2. A screwdriver points to the bolt that is the common ground point.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
Correct negative battery ground cable.
56567d1230679358-positive-negative-battery-cable-questions-86-93-mustang-oem-style-ground-cable.gif
Alternator troubleshooting for 86-95 5.0 Mustangs:
Do all of these tests in sequence. Do not skip around. The results of each test depend on the results of the previous tests for correct interpretation.
Changes in wiring for a 3G alternator are in red.
Engine off, ignition off, battery fully charged.
1.) Look for 12 volts at the alternator output. No 12 volts and the dark green fuse link between the orange/black wires and the battery side of the starter solenoid has open circuited.
3G alternator: Look for 12 volts at the stud on the back of the alternator where the 4 gauge power feed wire is bolted.
No voltage and the fuse for the 4 gauge power feed wire is open or there are some loose connections.
2.) Look for 12 volts on the yellow/white wire that is the power feed to the regulator. No 12 volts, and the fuse link for the yellow/white wire has open circuited.
Engine not running, ignition on, battery fully charged.
1.) Alternator warning light should glow. No glow, bulb has burned out or there is a break in the wiring between the regulator plug and the dash. The warning light supplies an exciter voltage that tells the regulator to turn on. There is a 500 ohm resistor in parallel with the warning light so that if the bulb burns out, the regulator still gets the exciter voltage.
Disconnect the D connector with the 3 wires (yellow/white, white/black and green/red) from the voltage regulator. Measure the voltage on the lt green/red wire. It should be 12 volts. No 12 volts and the wire is broken, or the 500 ohm resistor and dash indicator lamp are bad. If the 12 volts is missing, replace the warning lamp. If after replacing the warning lamp, the test fails again, the wiring between the warning lamp and the alternator is faulty. The warning lamp circuit is part of the instrument panel and contains some connectors that may cause problems.
2.) Reconnect the D plug to the alternator
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see 2.4-2.6 volts. No voltage and the previous tests passed, you have a failed regulator. This is an actual measurement taken from a car with a working electrical system.
Engine running, Ignition on, battery fully charged:
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see battery voltage minus .25 to 1.0 volt. If the battery voltage measured across the battery is 15.25 volts, you should see 14.50 volts
3.) Familiarize yourself with the following application note from Fluke: See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .You will need to do some voltage drop testing of several of the wires.
attachment.php
Start looking for these things:
A.) Bad diode(s) in the alternator - one or more diodes have open circuited and are causing the voltage to drop off as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
B.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Do the voltage drop test as shown in the Fluke tech note link. Measure the voltage drop between the alternator frame and the battery negative post. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
C.) Bad regulator that does not increase field current as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
D.) Bad sense wire - open circuit in sense wiring or high resistance. The yellow/white wire is the voltage sense and power for the field. There is a fuse link embedded in the wiring where it connects to the black/orange wiring that can open up and cause problems. Disconnect the battery negative cable from the battery: this will keep you from making sparks when you do the next step. Then disconnect the yellow/white wire at the alternator and the green fuse link at the starter solenoid/starter relay. Measure the resistance between the alternator end of the yellow/white wire and the green fuse link: you should see less than 1 ohm. Reconnect all the wires when you have completed this step.
E.) Bad power feed wiring from the alternator. Use caution in the next step, since you will need to do it with everything powered up and the engine running. You are going to do the Fluke voltage drop tests on the power feed wiring, fuse links and associated parts. Connect one DMM lead to the battery side of the starter solenoid/starter relay. Carefully probe the backside of the black/orange wire connector where it plugs into the alternator. With the engine off, you should see very little voltage. Start the engine and increase the load on the electrical system. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
Yes the stator wire is hooked up, I just upgraded to a nice 4ga wire so that might help, also upgraded the grounds from the battery to fender well, and the head to firewall. Im going to drive the car here in a few minutes to see if any of that worked.
Just got back from diriving the car, held 15v for about 10min then it dropped to 11ish and raised back up to 14, and then dropped back to 10-11v. When I got home I left the car running and hooked my jumper cables from the engine to - battery post(to see if I had bad grounds) the battery reads 11.5v with the car running, and 10.5 at the alternator.
Just upgraded to 4ga. wire, and all the wiring for the alternator is in good condition and is hooked up 100% right.
Shouldnt the alternator put out more than 10.5v? (with the engine at 1000rpm with a stock crank pulley, and stock fox alternator pulley) and Im going to have the battery tested to make shure its good.
You should see 14-14.5 volts at 1000 RPM and a warm eninge. A low battery will cause the alternator output voltage to be low.
Just got back from picking the battery up, they said its good, rated at 580cca and it puts out 596cca, and 12.51v, so what else could be wrong? the alternator tested good 3 different times, and has done this with 3 different alternators.
Battery termanals are clean, all the wires are in good condition, Im stumped.
Start doing a voltage drop test across all the connections when the voltage has dropped off. Pay special attention to the voltage sense yellow/white wire. Make sure that you have a good load on the electical system when doing the test. Put the lights on high beam and the heater blower on high speed.
63704d1282528484-new-alt-battery-still-have-charging-issue-86-93-5.0-mustang-alternator-wiring.gif
Alternator wiring
attachment.php
Old alternator power plug
50374d1179322644-progress-thread-3g-install-parts-pictures-mustang-3g-conversion-wiring.gif
