3G alternator with U/D pullies
Well, after much talk and little action, I finally motivated myself to do the 3G alternator swap yesterday. I bought a used 3G alternator from ebay for $50, which came with the harness so I could cut the stator wire off. I used 4 gauge wire without a fuse (temporary).
It charges better than the brand new 2G alternator I had, but not much. It can run the headlights just fine at 750 RPM (idle) but with the defrost and heater on full blast, the headlights will dim and voltage will go down. But if you give it a little gas and raise the RPMs up to about 850, it seems to have no trouble keeping up with the accessories.
I do have underdrive crank and waterpump pullies, but I have the 1 7/8" pulley on the 3G alternator. (is that stock on a 3g?) I noticed that the alternator's pulley had in and out play of about a 1/16th of an inch. And when you spin it, the bearings make an inconsistent hiss, leading me to believe they were well worn. The alternator is about 10 years old I believe. I took it to autozone, and it tested great! I think it was putting out about 160 amps or so at speed, but obviously it wasn't doing so great at idle.
Is it possible that the alternator could have lost its ability to make decent low RPM amps but remained just fine once it got spinning?
Can everyone with U/D pullies and a 3G alternator please give me some input on how well theirs worked? I'm not sure if I just got a bad one, or if they're all like this.
Thanks! (sorry this was so long)
I have underdrive pullies but i replaced the alt pulley with a ASP overdrive pulley which is 1 7/8" like yours. I also have a Sn95 electric fan and my car is AOD so it revs lower in gear.
I still get over 12 volts at idle with everything on. Rev to 850 and i get full 14.5 volts.
Hmm. Where do you test for how much voltage the alternator is putting out? At the battery? I'd still like to hear more experiences with this though. Thanks for the input!
Has anyone ever heard of an alternator making crappy low speed voltage but still making plenty voltage once it gets really spinning?
Yeah, that's how all alternators are. They need RPM to make voltage. The thing is, the 3G is supposed to be very good with making voltage with less RPM than a 2G.
To measure voltage, just measure at the battery.
yep, my friends is decent at idle (little better than stock) but really shows its power once it starts spinning.
90mustangGT - ahh i hate using peoples usernames to call them, thats your name byt the way?? anyway, off topic...even after all this time i dont think ive ever seen your car. can u post up some pics, i wanna see that biittch
i run my electric fan and headlights with voltage staying at 14.3 at idle. My idle is set at 900-950ish because of the cam though. I also run underdrives with the stock alternator pulley (slightly smaller than the 3G) which might help a little also. btw, its a 160 Amp unit.
Sorry, one more question: Did the 94-95 alternators come with a 2.5" pulley stock or a 1 7/8"? Because the one I got had a 1 7/8" pulley, and maybe the guy put it on to cover up for the fact that the alternator wasn't working to potential. Any thoughts on this?
