3G alternators
  • Thread starter Thread starter fastford91
  • Start date Start date Oct 18, 2007
fastford91
254
Niagara ,Ontario, Canada
Oct 18, 2007
  • Oct 18, 2007
i have a question about the 3G alternator! i know they are on 94-95 mustangs but are they on all of them or only on the 4.6? would they be on a 6cyl car also? the reason I'm asking is I'm going to go to the wreckers today and try to find one for my 5.0 also if i do find one is there any special brackets needed to install this or will it fit in the stock location? i have the wiring diagram that someone has supplied on here ! so any help would be great thanks guys!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 18, 2007
  • Oct 18, 2007
Any 94-95 Mustang has the 3G alternator you want. The 6 cylinder & V8 alternators are the same.
You use the same alternator mount bracket. A little cutting and filing makes everything fit.
See http://forums.stangnet.com/showthread.php?t=646825 for all the 3G install information you will ever need.
fastford91
254
Oct 18, 2007
  • Oct 18, 2007
thanks for the info !
fastford91
254
Oct 18, 2007
  • Oct 18, 2007
hey my autowreckers only has a alternator out of a 97 mustang ! will that fit or is it different?
J
jerryD
1,061
Gladstone, MO
Oct 18, 2007
  • Oct 18, 2007
as long as the mounting tabs are 180* apart it should work. you want one that looks like this
not like this
fastford91
254
Oct 18, 2007
  • Oct 18, 2007
OK thank you ! ill be going tomorrow to pick one up ! along with an aluminium drive shaft out of a aerostar!
fastford91
254
Oct 19, 2007
  • Oct 19, 2007
OK guys i got all the parts i said i was going to get! got the alternator for 60$ got the mass air for 50$ and the aluminum drive shaft for 75$ ! so all in all i say i made out OK! i have the wiring diagram for install of alternator and i know how to do the mass air! but Ive never done a drive shaft before! i remember someone saying i needed u-joints from napa 353? i believe! i went now I'm in Canada remember so the #'s might not be the same! the ones they have under 353 are ones for ford trucks and ones for amc! so my question is which ones do i need? do i need 2 or 1? and on the aluminum drive shaft i have bought it still has everything attached to it! I'm assuming these are the u-joints! and if so do i need to take these off and how! i know you have to remove the little clips but after that im stuck! i know you have to hit it to make them pop out but I'm not sure where to hit!never done this before! i can take a motor out and build a 400hrsp motor but i cant figure this drive shaft u-joint thing out! LOL any help would be good or pics if anyone has any or links to picks or instructions thanks guys sorry for the long post!
HISSIN50
34
129
Oct 19, 2007
  • Oct 19, 2007
Jrichker has info on the changes needed for an AWD Aerostar DS swap.
I use a ball joint press to remove the caps on the U-joints. You can also use sockets that are just bigger and smaller than the caps (for pressing the caps in and out with a hammer) but that's kinda brutal.
A mod motor MAF is not a plug and play modification. The transfer curve is different than that of the stock MAF.
Good luck with the new stuff!
fastford91
254
Oct 19, 2007
  • Oct 19, 2007
i got the u joints off using the socket method! it worked pretty easy with a c clamp! and the mass air i hooked it up and pluged it in and it works fine! its out a 95 3.8L mustang! ive heard of these working sometimes and not othertimes! fortunatly it worked for me! why i dont know! but it worked! now i just have to wait for jrichters post for the aero star aluminum drive shaft!
HISSIN50
34
129
Oct 19, 2007
#10
  • Oct 19, 2007
  • #10
fastford91 said:
........the mass air i hooked it up and pluged it in and it works fine! its out a 95 3.8L mustang! ive heard of these working sometimes and not othertimes! fortunatly it worked for me!
That's the right one. I thought you donor car was a 97. My bad.
Wait for Jrichker's post but your 353 U-joint sticks in my mind as being correct.
fastford91
254
Oct 19, 2007
#11
  • Oct 19, 2007
  • #11
yes it was out of a 95 the mass air and it works fine! the u joints are 353 from what i remember ! at my napa they listed 2 types one for ford tucks and one for AMC! both listed as part 353! now im in canada so i dont know if the #'S are different or the same ! so ill wait to see if someone can tell me what ones i need! im thinking it will be the ford turck ones but ill wait for jrichter to post i hope he sees this!
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
J
New to Mustangs/Fords
  • Joradan93Foxbody
  • Mar 2, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 2, 2026
Joradan93Foxbody
J
