  • SN95 4.6L Mustang Tech
3rd gear
  • Thread starter Thread starter 02_2VStang
  • Start date Start date Apr 11, 2004
02_2VStang
73
Cary, N.C.
Apr 11, 2004
  • Apr 11, 2004
anyone have trouble getting in to 3rd when racing w/ pro 5.0 shifter? how can this be fixed?
pony_vert02
285
AUSTIN,TX
Apr 11, 2004
  • Apr 11, 2004
i only had that problem with the stock shifter...afterward i bought a steeda tri-ax short shifter...i haven't missed since....could possibly be when you are racing, you're not totally engaging the clutch?
2013 Geee T
805
Oak Park, CA
Apr 11, 2004
  • Apr 11, 2004
Are you saying you cant find it or its doing something else like grinding?
02_2VStang
73
Cary, N.C.
Apr 11, 2004
  • Apr 11, 2004
no the clutch is all the way in. just real hard to get in when im at high speed, nothing grinds. but i didnt have a problem w/ the stock shifter
02_2VStang
73
Cary, N.C.
Apr 11, 2004
  • Apr 11, 2004
could be something i have to get use to w/ the shorter shifter? i just didnt know if it was maybe a known problem
pony_vert02
285
AUSTIN,TX
Apr 11, 2004
  • Apr 11, 2004
could also be part of our famous "tremec transmission" issue..
JonJon
4,801
back in Marylands
Apr 11, 2004
  • Apr 11, 2004
I've never had trouble getting into 3rd, with stock or Pro 5.0
twogts4us
4,188
12
79
Dunedin, FL
Apr 11, 2004
  • Apr 11, 2004
Dittos here on my 02 GT with a Tremec...no problems at all. It's stiff when it's cold, but before I even leave the garage, I row thru the gears once or twice, then I am on my way without any issues (except trying to remember to turn the traction control OFF!!!)
AlienQuiksilver
21
  • Apr 12, 2004
T 3650 common problem
It's the crappy tremec 3650. My car won't go into 3rd if I try to shift above 5k RPM's. If i shift it slowly ... it will go in, but shifting slowly causes the engine to drop below the 5,000 RPM range. A lot of people have this problem. Check out Tremec 3650 issue ... threads. I had this problem with stock shifter, and Steeda Tri-ax. We should count our blessings, cuz this is what the better T 3650 trannys do!
02_2VStang
73
Cary, N.C.
Apr 12, 2004
#10
  • Apr 12, 2004
  • #10
yeah, shifting slowly there is no problem, just when at high rpms, but thanks for the input anyways. tremec 3650 definatly blows
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
