I love how my car sounds. And if you have Flowmasters, 4.10's will put you outside of the drone-zone, so it shouldn't be a problem.squares98 said:Everyone says the mpg's bother them, that should have nothing to do with it. The increased constant noise levels should be the concern because that can get a little annoying. 4.10's do have a little more uumph, but if you are not a lead foot and just like to cruise in peace without feeling all wound up maybe a 3.73 will make you happier. They still get you moving quicker, and you get longer gears too.
It's not drone. It's just loud.Gearbanger 101 said:The gear RPM ain't bad, but man you've got some brutal drone! Guess I know I'm not going with a set of Magnapac's.![]()
Spreadman said:I love how my car sounds. And if you have Flowmasters, 4.10's will put you outside of the drone-zone, so it shouldn't be a problem.
If you drive the speed limit, your mpg will not suffer anymore than with stock gears.
jrc_03_gt said:Wrong! Its dead on the nuts. I have checked it ! I have a 3650 tremec trany.
Started off in first. No, it doesn't get annoying. The car makes some very nice noises during shifts (exhaust related) so I don't mind it. But that was starting off slow, if I lay into it, I can go much higher.Ghostface said:on the second vid where your driving from a dead stop, are u starting the car in first or second? If it's first it seems like ur only on it for a second and shifting way before your even at 10 mph. Does that get annoying having 1st be so short? Thanks for the great vids..
